Top speed limits?
Old Jan 7, 2011 | 11:59 AM
groundwire's Avatar
groundwire
Default Top speed limits?
was asked about if the vette had a limit on top speed by the ecu? and does it change on the convertible when the top is down? Thanks for you insite
Old Jan 7, 2011 | 12:04 PM
bigred6906's Avatar
bigred6906
No limit via the ecu. The vette is drag limited. You will go as fast as the combination of your aerodynamics and power will allow. It will definitely change when the top is down. That will create more drag and would probably slow you down a bit. Expect the C6 to hit somewhere in the late 180's bone stock.
Old Jan 7, 2011 | 12:11 PM
groundwire's Avatar
groundwire
Thanks bigred...didn't think so but wanted to double check
azc62006's Avatar
azc62006
Default verts
verts arent made to go fast there for looking pretty!!!! just playing. i heard there was a speed limiter?
Old Jan 7, 2011 | 12:14 PM
azc62006's Avatar
azc62006
Default limits
i found this on the forum.. sorry to bother you again
Old Jan 7, 2011 | 12:25 PM
07MontRedcp's Avatar
07MontRedcp
Sorry, but there is a speed limiter, for my '07 it is 186 mph, but if you have HP Tuners you can change it.
BJK
Old Jan 7, 2011 | 12:47 PM
bigred6906's Avatar
bigred6906
BJK
I have never known this to be true. IF IT IS TRUE, it doesn't make a difference as these cars in stock form aren't gonna get much more than the 190 range anyway. Let's see what others have to say when they chime in. Now I'm curious. I took my LS2 M6 Coupe up to 182mph on a "closed course"
Old Jan 7, 2011 | 12:51 PM
07MontRedcp
See my edited post. With my car there would be a reason to up the limit. They bumped the limiter to 195 mph for the LS3.
BJK
Old Jan 7, 2011 | 12:57 PM
vettedoogie's Avatar
vettedoogie
Well, 140 with the top up in my '05 feels like 80 in any other convertible I've been in.
Old Jan 7, 2011 | 01:00 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Aren't the tires rated for 186 mph on the base cars and GS?
Last I heard, the original manufacturer was not allowed to sell a car that could exceed the tire rating. So it would make sense to put the 186 limiter in there, just in case.
IIRC; when I bought my 1998 Camaro Z28, one of the tire choices was not speed rated and those cars came with a limiter something around 125 mph. If you put on better tires, you were still stuck with the limiter unless you could find a tuner to remove it.
Old Jan 8, 2011 | 11:39 AM
Bill Suttie's Avatar
Bill Suttie
This is correct. For legal CYA reasons, production cars are speed limited to max tire speed. What you do with the car after you own it is your business.
Old Jan 8, 2011 | 11:55 AM
groundwire's Avatar
groundwire
So is there a limiter on the 05 c6? not that I am looking to drive at those speeds much but would really like to know what the deal REALLY is.....
Old Jan 8, 2011 | 12:18 PM
HOXXOH's Avatar
HOXXOH
There is a limiter at 158 mph until you turn off the traction control on my '08. I suggest turning it off early, so you don't get the power surge at the limit.
Old Jan 8, 2011 | 12:28 PM
NYC6's Avatar
NYC6
That is not for Corvette. Corvettes, AFAIK arent available in 4WD. That is for the Tahoe and they are values not mph.
The the base Vette, Z06 and ZR1 sport ZR speed rated ties. They are only tested to 186 and are worn by cars that are faster than 186. The Z06's top speed is 195(?) on ZR rated tires and the ZR's is over 200.
There is no factory installed rev limiter on a C6 Corvette. They are drag limited.
Old Jan 8, 2011 | 12:36 PM
MARSC6's Avatar
MARSC6
The Goodyear supercars have a (Y) rating which is over 186.
Old Jan 8, 2011 | 12:41 PM
07MontRedcp
If by rev limiter you mean RPMs, you are dead wrong. The ecm will cut fuel at xxxx rpm.
If by rev limiter you mean MPH, then again you are dead wrong. Go back and look at the HP Tuners screen shot I put up in post #6.
BJK
Old Jan 8, 2011 | 12:42 PM
markmott's Avatar
markmott
St. Jude Donor '16
My Diablo Predator says the top speed limiter is 186.5mph, which it will change, dont know why anyone would want to.
To Top speed limits?
Old Jan 8, 2011 | 12:50 PM
QUAKEJAKE's Avatar
QUAKEJAKE
I can't recall ,Is drag and rev limited one in the same?
Old Jan 8, 2011 | 01:10 PM
NYC6's Avatar
NYC6
BJK
Rev limiter was obviously a brain fart typo on my part. Meant speed limiter.
A generic pic of an HP page proves nothing. But to humor you I'll play along. Whats enable at 1500rpm? Whats a speed limiter 2 at 80mph? Why at the bottom of the page does it say Max speed 318? Where does it say anyhing for Corvette? Where is a GM official letterhead with this 'data'? That is a totally worthless picture.
Old Jan 8, 2011 | 01:12 PM
Marc V.'s Avatar
Marc V.
My buddy hit 180 MPH in his '08 vert. Then the fabric top tore off and seperated from the frame. It WILL go fast, but do you really want to?
I never turn off my TC, and I did a little over 180 MPH.
