Rear Suspension sqeaking creaking
My car is 07 z51 lowered with hardbar bolts. I have this awful creaking noise coming from the rear suspension that seams worse in the cold. Just getting in and out of my car the suspension squeaks. It is any time the car goes up and down. I jacked it up to look and car would creak each time I pumped the jack. All the bolts seemed really tight. Any help or input would greatly be appreciated.
http://forums.corvetteforum.com/c6-t...-fittings.html
check out the picture.....this is where you lube it..
Deco foam (02-04-2020)
I will take a look first thing in the morning.
Midnightstriker (04-27-2021)
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
anyone think it's possible the end links could also do this?
I have a similar problem. Seems when I turn at slow speeds left, my suspension makes a poping noise. Seems to have gotten worse since its gotten colder out. Previous owner had the car lowered with bushings. Help
That sounds like the tie rod ends, I had that issue too like a year or two ago.
well did you find out where the squeaking / creaking was coming from?
I went thru 2 sets of the WCC lowering bolts, and they kept wearing out where it would be metal on metal. I always lubed them but they would only last 3-5K miles. I got factory bolts on the back now and cut them, I will never use aftermarket bolts again
I had greased the derk fittings in the rear and my car was silent for about two weeks and the creaking came back. From other things I have read I believe the Mobil 1 grease is the culprit, It has been known to get oily and leak back out. I am going to try the valvaline synthetic and see if that helps.
To the guy that posted about WCC lowering bolts, yea those things are horrible. Were worn out on my car in 6 months, and I replaced with Hardabar lowering bolts. Hardbar was bad customer service, but seems to be a superior lowering bolt for over a year now.
I greased the derk fittings again, but this time with Valvoline synthetic grease. So far the noise is gone. I had used mobil 1 before and it leaked out. It got all over the inside of my wheels, and was getting on my brakes.
My 05 vert does the exact same thing! Worse when cold but every time I get in or out of my car is creakes. Yoy can even push down just a little on the rear hatch and it creaks! My car is an 05 non-z51 so I don't have anyplace to grease. Also, my car is lowered on the stock bolts. Can anyone tell me how to stop the creaking, it drive me crazy and makes a 60K car sound like a 5K beater!
The car has less than 30K miles on it. Tie rods will not go out that soon. It's got to have something to be with the lowering of the car on stock bolts.
