Drivers window has stopped about three inches from top.
Window will retract all the way but stops when trying to close.
Motor slows to stop position. Sounds like something may be binding travel of window.
How do you remove door panel to repair.
Anyone experienced this situation, suggestions welcome?
Thanks all.
You first have to take out the screws behind the small little cover by the door armrest.Then it's a matter of prying the thing off the door.It makes aton of noise because of those plastic things holding it in,but don't worry,you're not breaking it.I'd get a bunch of those things from home depot too because you will break them.I forget what they are called though as I'm not totally awake yet! Might be something up in DIY faq section on this too.
Go to DSVettes website. They have instructions on their site to remove the door panels. Part of process to install the leather door handles, etc. Has good tips, etc.
Here's a tip when putting your door panel back on. Line up all the pins and push them in first. Then with the palm of your hand bump the top hangers into place. This is much easier than trying to line up and hang the top of the door first and then put the pins in place.
I'd look into the re indexing first, up and down and see if it slowly adjusts. 2nd, I'd disconnect the battery, seems like I remember a recent post where this corrected a similar problem. I'd do this before dismantling my door. My 2 cents.
My memory is that a minute or two of disconnect didn't fix it, but 30 minutes did.
