Water Pump
Old Jan 21, 2011 | 07:29 PM
itshervette's Avatar
itshervette
Default Water Pump
The smell of antifreeze is never a good thing. Came home tonight, looked under the hood of my 2005 & antifreeze is everywhere, including puddling on my garage floor.
Anyone replaced their own water pump? Was it difficult to do? Anything special that I need to know?
Thanks, in advance.
Old Jan 21, 2011 | 07:52 PM
Thrill6's Avatar
Thrill6
Never replaced one on a vette, but have replaced them on several vehicles including my IROC-Z. General procedure is to drain the anti-freeze, remove the drive belt(s), unbolt the water pump, clean off old gasket material from engine, install new water pump. It's also a good idea to replace the thermostat when you have the old pump off because its usually easier to get to the thermostat housing with it off and the old thermostat is probably due for replacement anyway.
Old Jan 21, 2011 | 08:02 PM
RicK T's Avatar
RicK T
Just asking, are you sure it's the water pump and not a hose or radiator tank?
Here's one helpful thread for the pump, just read the whole thing, don't stop at post #1.
http://forums.corvetteforum.com/c6-t...ment-help.html
Old Jan 21, 2011 | 10:35 PM
itshervette
Thanks, Gentlemen!
Old Jan 21, 2011 | 11:46 PM
GotVett?'s Avatar
GotVett?
Had mine replaced and it was covered under the drivetrain warranty thank goodness. Maybe not that hard to do, but . . . . glad I left it to the mechanic to do.
To Water Pump
