HELP!!! Alignment Question!
Old Jan 22, 2011 | 01:23 PM
America'sSportsCar's Avatar
America'sSportsCar
Default HELP!!! Alignment Question!
Please help! I've been doing a search now for over an hour and I still can not find a solid answer! I'm going to have a 4 wheel alignment done on my 2006 F55 C6. I want it to be set up for the next step up from street driving but not too aggressive like track driving. I've read many different opinions about the factory specs. Some say don't use them some say do.
In short, what alignment numbers for camber, caster and total toes should I use!!!! One guy wrote he does over 1500 a year and he uses 1/4 negative camber and 1/8 inch total toe in. Great but....everything I see is in tenths, not fractions- so I'm confused!!
Any insite would be GREATLY appreciated.
Old Jan 22, 2011 | 01:28 PM
tim414's Avatar
tim414
St. Jude Donor '12
0.25 and 0.125....???
Old Jan 22, 2011 | 01:33 PM
America'sSportsCar
That's what I thought too but that would be way out of factory tolerance.
Old Jan 22, 2011 | 01:36 PM
Jeff78's Avatar
Jeff78
That would be me, 1/4 negative degrees camber front and rear. As far as toe, we measure in inches and not degrees so my toe reading is 1/8" toe in total front and rear. I can get you a degree reading on Monday for toe if you need.
You probably will get many differing opinions about what to run but this is what works for me, and I do in fact run roughly 1500 vehicles yearly on the alignment racks. I have these settings on my C6, along with many other C5's and C6's along with Z06's. These are not track numbers, but on a little back road run last year with me in the lead I hit up to .82 on my g-force meter.
Old Jan 22, 2011 | 01:54 PM
America'sSportsCar
Thanks Jeff78! Yes, you are the one I was referring to. I will tell the service guy what you said. I hope his machine is in inches! I assume the steering number should be at zero, right? I'm heading out in the next 10 minutes to leave to have it done, so if I don't reply back right away, that's why.
RicK T's Avatar
RicK T
Do you know where yours is now? It might be enough to just set it up correctly at the high side of factory spec. If not then you could try the factory Z06 (FE4) settings. Here's an informative thread with the '08 factory specs chart included. The '05-'07 rear specs are just a little different.
http://forums.corvetteforum.com/c6-c...post1563071618
Old Jan 22, 2011 | 01:59 PM
Jeff78's Avatar
Jeff78
You must mean thrust angle when you say steering number. Yes that should be zero or extremely close to it. Simply put that is how true the rear end is running to the front end, dog tracking in old school terms.
Old Jan 22, 2011 | 02:03 PM
America'sSportsCar
Thanks Rick T! No, I don't know what my factory settings are right now. When I changed all 4 tires last year, the front and rear tires were worn a little more than normal on the inside edge. So, my toe-in might be off a little I'm guessing. I'll check that thread you pasted for me, thanks again
Old Jan 22, 2011 | 02:08 PM
America'sSportsCar
Yes, the thrust angle! Thank you. One last question, what should the "caster number" be? I know you use inches but the factory spec is 7.90 degrees +/- 0.60 degrees. What would that be in inches? Thanks a million!
Old Jan 22, 2011 | 02:13 PM
Jeff78's Avatar
Jeff78
Caster is measured in degrees like you said. Keep it in the range you have mentioned or narrow it down for the tech to between 7.5 to 8 degrees. Just make sure that the caster is matched from left to right, you do not want any more than 1/8 degree difference. Front end only there is no caster adjustment on the rear.
Old Jan 22, 2011 | 02:23 PM
America'sSportsCar
PERFECT!!!!!!! Thank you sooooo much Jeff78 as well as Rick T and tim414. Okay guys, I'm out to get my alignment done!
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
more than normal? if you supposedly take it to the next step from Normal street driving, what Rick may be saying is A) your settings may already be there, and B) you can, and most likely will experience more tire wear in the areas you mentioned. in other words, to cause the kind of wear you already have may be at a slightly optimized street setting. you want more, you can get it. but don't expect your tires to last longer necessarily and do expect them not to.
Old Jan 22, 2011 | 03:09 PM
07MontRedcp's Avatar
07MontRedcp
http://www.pfadtracing.com/blog/wp-c...-alignment.pdf
BJK
To HELP!!! Alignment Question!
