Trickle charge
Old Jan 24, 2011 | 09:59 PM
Buy-Low's Avatar
Buy-Low
Default Trickle charge
So it's been below zero here in CT for multiple days. I just attached a 2-10-50 amp trickle charge to my battery ar at 2 amps as it won't be seeing daylight for quite some time. The box says 3-5 charging time. I assumed you could lever this attached indefinitely. No?
Old Jan 24, 2011 | 10:10 PM
RicK T's Avatar
RicK T
No, you can't......unless the unit specifically states it is also a float charger. A constant 2 amps will cook the battery pretty quickly. You need, or should have, a battery maintainer. Battery Tender and CTEK are the most common, popular. Many here have posted that you can get a Schumacher at WalMart. Don't know much about those though.
Old Jan 24, 2011 | 10:17 PM
Mike Green9's Avatar
Mike Green9
What RickT says. Get a C-TEK, connect it, and it will do the job for as long as you like.
M....
Old Jan 24, 2011 | 10:21 PM
Marc V.'s Avatar
Marc V.
No trickle charger.
You need a battery tender/minder. These you can leave hooked up indefinitely as it monitors the battery volts and only charges when needed without overcharging.
Old Jan 24, 2011 | 10:39 PM
KSCRUDE's Avatar
KSCRUDE
Yes I agree with the previous posters.
Old Jan 24, 2011 | 10:42 PM
WMark's Avatar
WMark
St. Jude Donor '11
Originally Posted by Marc V.
No trickle charger.
Having suffered DBS with a nine month old battery in a 2010, studied this forum extensively. Battery tender. Several good brands recommended. Regardless of cost, cheaper and less frustrating than being stranded with a dead battery. Once dead, most batteries won't jump.
Cheap insurance.
Old Jan 24, 2011 | 10:46 PM
carjo's Avatar
carjo
Old Jan 24, 2011 | 10:48 PM
Just Buy It's Avatar
Just Buy It
Get a Tender, what ever brand. Its worth it.
Old Jan 25, 2011 | 07:28 AM
Buy-Low's Avatar
Buy-Low
Thanks all, everyone here is so helpful!
Old Jan 25, 2011 | 08:01 AM
Weasel's Avatar
Weasel
Here in Michigan it's been very cold too. And it affects more than battery juice. Today it's supposed to be 32, which means that the engine block, heads, and all other dense materials will stay freezing while the air around them is warmer. This will coat your engine and other parts that have stayed cold, with condensation. The "new" will soon disappear from your Corvette's bright engine parts unless you start it up. It becomes a kind of high-class dehumidifier.
Old Jan 25, 2011 | 08:31 AM
Foxer55's Avatar
Foxer55
Yeah, after several weeks of non-use my battery took a dive. Was sitting in the cold garage. Looked on the forum here and as a result of one recommendation, ran over to Walmart and picked up a tender for $20. Hooked it right up.
Old Jan 25, 2011 | 10:04 AM
dvilin's Avatar
dvilin
Old Jan 25, 2011 | 08:56 PM
Can Can's Avatar
Can Can
Before you run out and spend money on a new charger, read the instruction manual that came with yours. If it's a newer charger, there's a very good chance it will shut itself off once the battery is charged.
Paul
To Trickle charge
