Engine light question
Old Jan 26, 2011 | 07:56 PM
6318's Avatar
6318
Default Engine light question
I got the rear tires replaced on my 09 Z06 today and on the way home, the check engine light came on. The manual says that changing tire size can trigger this, but I replaced the tires with the stock GY.
Think it could still be causing this? I'm still under warranty, but live in rural America and the nearest 'big city' dealership is a couple of hours away (which is where the tires were changed)...not sure when I'll have the time to make the trip again.
...any advice welcome!...
Old Jan 26, 2011 | 08:03 PM
EVRose's Avatar
EVRose
Did you happen to put gas in it on the way home. Maybe your gas cap is not sealed properly.
Old Jan 26, 2011 | 08:05 PM
6318's Avatar
6318
I didn't...but I plan on resealing just to make sure!
Old Jan 26, 2011 | 08:07 PM
RicK T's Avatar
RicK T
Do you have a code reader or access to a major auto parts store that might loan you a reader?
Old Jan 26, 2011 | 08:24 PM
JoesC5's Avatar
JoesC5
Disconnect the battery for 5 minutes to clear the CEL, then initialize the windows. If there is an ongoing problem, the CEL will come back on. If it's a one time fluke, then clearing the CEL will save you the hassle of taking your car back to the dealer.
Old Jan 26, 2011 | 11:15 PM
6318's Avatar
6318
I'll look around for a code reader, and if I can't find one will try unplugging the battery...
Thanks guys!
Old Jan 26, 2011 | 11:23 PM
NYC6's Avatar
NYC6
You should go buy a code reader/eraser. You can get one at any of the larger auto parts joints for $50-100 for a useable basic model. Great tool to have in the tool box. Takes maybe 2 minutes to pull the code and erase.
Old Jan 27, 2011 | 12:20 AM
ejbarre's Avatar
ejbarre
If you have ONSTAR, call them. They can do a diagnostic check & tell you what the problem is.
Old Jan 27, 2011 | 12:40 AM
MARSC6's Avatar
MARSC6
Amazon currently has a really good price on the Actron CP9410 $45 delivered.
Old Jan 27, 2011 | 09:24 AM
haljensen's Avatar
haljensen
The only thing Onstar will tell you is "you have a check engine light, take it to the Dealer service dept. in the near future". Unless something drastic has changed they will not tell you what the problem is or give you the exact code.
Old Jan 27, 2011 | 11:54 AM
Marc V.'s Avatar
Marc V.
I don't think its possible for the check engine light to come on just from a tire change.
Where in the manual does it say that?
Check engine light is for engine and emission controls. Even a problem with a TPMS wouldn't cause a check engine light.
Old Jan 27, 2011 | 06:30 PM
6318's Avatar
6318
Pg 3-43: "...replacement of the original tires with other than those of the same Tire Performance Criteria (TPC) can affect the vehicle's emission controls and can cause this light to come on."
The tires are same as the original, GY Supercar...but they look a lot taller...maybe I just wore the tread down more than I thought!
Old Jan 27, 2011 | 07:06 PM
dpigguy's Avatar
dpigguy
My '08 has had several CEL's for which OnStar has given me the codes when they were called. Maybe its changed but since Dec. '07, been getting these from the "blue" button prior to going to dealer for work.
Old Jan 28, 2011 | 01:44 AM
Blaq Ops's Avatar
Blaq Ops
Onstar has told me what code they were receiving and what it was for. They also let me know that the vehicle was safe to drive and what course of action to take.
Old Jan 28, 2011 | 09:26 AM
haljensen's Avatar
haljensen
Giving the exact code must be a recent addition. OnStar wouldn't for my '05 so I tried it with my '08 (removed the fuel fill cap) and they would only tell me that it was emissions related and to take it to the Dealer. No OnStar for me after the free trial.
Old Jan 28, 2011 | 09:34 AM
LMB-Z's Avatar
LMB-Z
Call me... I live in one of your neighboring "big cities" and will be happy to drive your car to the dealership for you.
Hope you get it figured out.
ps I just changed tire size and did not get a check engine light.
Old Jan 28, 2011 | 12:03 PM
ejbarre's Avatar
ejbarre
That is what ONSTAR did for me.
To Engine light question
Old Jan 28, 2011 | 03:46 PM
6318's Avatar
6318
Hit onstar...they said it was an exhaust error...
...looking into a code reader/eraser...if I erase, will the computer log that and get me into trouble with the warranty?
Old Jan 28, 2011 | 04:01 PM
jcb_njb's Avatar
jcb_njb
I have a 2008 had the CEL come on after re-fueling one day. I reset the gas cap and the CEL did not go away. Took to the dealer and they found the "Evaporative Emission Canister Solenoid" (what ever the hell that is) to be defective. I understand this can just suddenly go out.
Old Jan 28, 2011 | 04:08 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Nope, GM will not have a clue that you read and erased the codes. You will simply start "fresh" with history and codes in the ECM.
Elmer
