Speedsensor?
Old Jan 29, 2011 | 03:40 PM
Frank's C6's Avatar
Frank's C6
Default Speedsensor?
Hello,
where can I find the Speedsensor(may be Pics),because the Speedometer doesn't work etc.
Can somebody help me?
Frank
Old Jan 29, 2011 | 04:58 PM
haljensen's Avatar
haljensen
The "sensor" for the speedometer is on the ring gear in the differential.
Old Jan 30, 2011 | 03:34 PM
Frank's C6's Avatar
Frank's C6
Thank you.
Old Jan 30, 2011 | 04:50 PM
Thrill6's Avatar
Thrill6
If the speed sensor was bad, I would think you would be getting lots of messages on the DIC about traction control, ABS, etc. If your not, I would think that the speedo is bad. With a professional level (and some high end consumer) scanners you can display the speed. If this is working, then your problem is definately not the sensor.
To Speedsensor?
