speaker hiss
Old Jan 29, 2011 | 08:56 PM
azmg's Avatar
azmg
2nd Gear
Default speaker hiss
I have the blose speakers and they have a very bad hiss (static noise). Also, they sound very loud even at 3 bars. I have a feeling the amp gain is set way too high. Is this something that can be adjusted and if so, where is the amp located? Thanks!
Old Jan 29, 2011 | 09:50 PM
Blaq Ops's Avatar
Blaq Ops
I'm having a similar problem.
Old Jan 29, 2011 | 10:02 PM
Eritosthenes's Avatar
Eritosthenes
This is a problem area few dealerships can deal with. However, if you troubleshoot its symptoms as though it's a home stereo, you almost always find it's an RF cable problem from the antenna. That hiss you hear is the amplifier cranking its guts out trying to produce audible sound from a very weak input. Restore the input signal with a good cable connection and you can back the amp off 30-40 db (along with the hiss).
Old Jan 29, 2011 | 10:12 PM
K9KUZ's Avatar
K9KUZ
Old Jan 29, 2011 | 10:47 PM
keyplyr's Avatar
keyplyr
People used to hiss when they heard my Bose speakers.
Old Jan 29, 2011 | 10:52 PM
DWS44's Avatar
DWS44
2022 C8 of the Year Finalist - Modified
2022 C7 of the Year Finalist - Unmodified
How/where would one adjust this? I always thought the Bose "hiss" was "normal" in these cars. My 08 had it, and so does my new GS. While a long ways from perfect, the overall sound quality is OK for my tastes, but I would love to get rid of the hiss if its really possible w/o replacing the whole system.
Old Jan 30, 2011 | 08:50 AM
lastcowboy's Avatar
lastcowboy
the head unit is located next to fuses pas.side kick w.
have you added some new elec.? it could be picking that up and giving you static
Old Jan 30, 2011 | 01:21 PM
azmg's Avatar
azmg
2nd Gear
Default Thanks for all the replys!
I did add the m2w to the fuse box... Maybe I should try removing it to see if it helps. If not I will have to read up on detecting bad cables (or maybe just start replacing ones until it improves)
Old Jan 30, 2011 | 04:27 PM
lastcowboy's Avatar
lastcowboy
Old Jan 30, 2011 | 06:49 PM
Eritosthenes
With the volume control. The problem I'm describing is insufficient input being amplified (along with thermal background noise) to an audible level.
Old Jan 30, 2011 | 08:49 PM
LMB-C6's Avatar
LMB-C6
For hiss when the volume is low, try turning off the auto volume feature. My speakers hiss quite noticeably when it's on, and are quiet when off.
To speaker hiss
