problem with headlights
Old Jan 30, 2011 | 02:45 AM
08c6john's Avatar
08c6john
4th Gear
Default problem with headlights
Hi I am new to the forum thing so please be patient with me. My name is John and I have a question about my 08 c6 that maybe someone can help me with. a couple of weeks ago both the low beam headlights stopped working. They soon began working again for a while. now they are not working again. High beams work fine and tail lights work fine. Does anyone know what could possibly be the problem? In need of help.
Old Jan 30, 2011 | 02:53 AM
DONALD HALL's Avatar
DONALD HALL
Hi John, Donald here, Have not had that problem or read about it. However a loose connection or bad relay. Check fuse for tightness in slots. I believe each low hid beam has its own ballast so if both are affected at the same time I would be looking for a common problem with power to both. Electrical problems that come and go can be difficult.
Good luck and welcome to the forum.
Old Jan 30, 2011 | 02:58 AM
08c6john's Avatar
08c6john
4th Gear
Thanks Donald, I will check the fuses and take it from there. I appreciate the input.
Old Jan 30, 2011 | 08:21 AM
CGZO6's Avatar
CGZO6
If it's not the fuses or relay, it's probably a bad BCM (body control module).
Old Jan 30, 2011 | 08:30 AM
Rocketmanwpb's Avatar
Rocketmanwpb
You may still be under warranty, I would get the car to the dealer as soon as possible.
To problem with headlights
