My Horn Doesn't Work
Old Feb 1, 2011 | 05:56 PM
easyrider13's Avatar
easyrider13
Default My Horn Doesn't Work
2005 C6
I pressed the horn "button" for the first time in months (maybe years) and it didn't work. I checked the fuse (#2) and it looked fine.
Are there any common problems I should check for before bringing it to Mr Goodwrench (for the first time since delivery in February, 2005) under by virgin GMPP?
Old Feb 1, 2011 | 05:59 PM
Vette_DD's Avatar
Vette_DD
Others here have posted about fuses looking good, but turned out to be bad. Just to be on the safe side, I'd actually replace that fuse with a new one before I took it to the dealer, especially if that seems to be the only problem area.
bimmerborn's Avatar
bimmerborn
Does "Panic" button on the fob work?*
* No intention to answer a question with another question. Want to know if actual horn is broken or something else.
Old Feb 1, 2011 | 06:04 PM
gunterwalker's Avatar
gunterwalker
From: Cape May, NJ; Guntersville, AL; Orange Beach, AL
I was going to suggest you change the fuse regardless of what it looks like and does it work when you hit the lock button on the FOB or use the panic button? Try both of those things then let us know. If the panic button works it might be the sensor in the steering wheel. Mine went out in my 03 2500 after a few years but warranty paid for the fix.
Old Feb 1, 2011 | 06:13 PM
easyrider13
Thanks, guys
I just tried the "panic" button and the horn worked fine.
I then worked the horn contacts in the center of the steering wheel and the horn started working with a little manipulation.
Maybe the contacts had become oxidized.
Moral of the story: Sound your horn every month or so.
Old Feb 1, 2011 | 06:17 PM
rchbn's Avatar
rchbn
I live in AZ where they don't use blinkers for some reason. So I use my horn once a week at least!
Old Feb 1, 2011 | 06:26 PM
Vette_DD's Avatar
Vette_DD
And post here to get more and better options before taking it to the dealer.
Old Feb 1, 2011 | 07:49 PM
CH-Z51's Avatar
CH-Z51
From: The Great Pacific Northwest...........I carry a gun cause a cops too heavy.
Glad you brought this up, I've had my C6 over 5 years now and I'm not sure but I don't think I've ever used the horn. Guess I should give it a test.
Old Feb 2, 2011 | 12:27 AM
Rossi6998's Avatar
Rossi6998
Thanks, guys
Don't have that problem in LA... It's a challenge not to honk your horn on a daily basis while driving the freeways....
Old Feb 2, 2011 | 12:36 AM
Marc V.'s Avatar
Marc V.
Just add one of these horns.
To My Horn Doesn't Work
