Waranty issue advise needed
Problems reported by me to the service writer
1) Oil leak.
2) M6 Transmission shifting problem.
3) AC and climate control system not working properly.
4) Power top not opening and closing properly.
Dealer’s findings
1) The dealer found that the oil leak was a pan gasket R&R (Approved)
2) M6 problem was bad syncros. Replace transmission (Approved)
3) AC had 1/2 of a pound of Freon in the system they charged it and no leaks detected(Not approved) I still can’t figure this one out
4) Power top bad switch and realign (Approved)
After completing all repairs the dealer took the car out for a test drive this past Saturday and during the test drive the Harmonic balancer slid backward into the motor and eat the belt in the process. (the service writers explanation)
After doing much research i have found that my year has had a service bulletin out for this same issue and is a known problem for the 05 early model....
My question is now that warranty has expired the company is balking at the replacement..Who's responsibility should it be on? Keep in mind the car has never been released to me as being completed.
Yes, the dealer has had my car for almost 2 months!!!
This is probably going to be a tough one for you to win, sounds like they're going to fight you on it. Seeing as how they've had the car for 2 months, it really should be on them... especially since you haven't accepted it back from the original visit for warranty work.
I've got 4 Chevy's in my garage/driveway and hearing things like this really make me question why some of the times.
On more than one occasion, I've had warranty work completed and approved on Chevy vehicles that had just passed the warranty experation date. They can do it, it's just a matter of whether they will or not.D
http://forums.corvetteforum.com/c6-c...39-owners.html
Thanks for the thread find!
If it is, you'd have to pull out your contract to verify any exceptions.
First Exteneded service company... Zero deductable
Also, the GM dealer can tell from their computer if this was done.
As to the above comment re lemon law, does not apply to your car, imo, since it is not a new car.
I'll also add that the timing of the incident was just bad dumb luck. Could have easily happened to you driving home from the dealership.
I'm not discounting the Service Note out there but just because it happened while in the dealer's possession doesn't make them automatically liable to fix it.
