GS conversion wheel question
Old Feb 3, 2011 | 08:29 PM
baxterboy's Avatar
baxterboy
Default GS conversion wheel question
Gentleman, I am getting ready to do a complete front and back GS conversion on my 2008 C6 coupe. The question and confusion I have is I am going to install reproduction Z06 motorsport wheels all around. I here people ordering front c6 offset and rear Z06 offsets. This is confusing the hell out of me. I want to put as big of tires as I can fit in the rear as I am supercharged and every little bit will help. Please advise if possible what I need in this wheel style. Size front and back. Thanks in advance.
Old Feb 3, 2011 | 08:53 PM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
You're confused because some just do the wide rear so need base front offsets.
If you are doing wide front and rear then you need GS/Z06 offsets.
David
Old Feb 3, 2011 | 08:55 PM
ncvette_1FUNRIDE's Avatar
ncvette_1FUNRIDE
2015 C6 of the Year Finalist
If your going with a front AND rear conversion, you can use Z06 offsets and widths for both the front and rear wheels.
Z06 = front: 18 inch x 9.5 inch, +40 offset
rear: 19 inch x 12 inch, +59 offset
If you go aftermarket wheels, you can go even wider. 10" front and 12.5" or 13" on the rear
Old Feb 3, 2011 | 09:06 PM
johnodrake's Avatar
johnodrake
Moderator
David
Old Feb 3, 2011 | 09:57 PM
baxterboy's Avatar
baxterboy
I appreciate steering me straight on this. Just seemed really confusing when I seen 2 different styles of offsets. Thanks again. I will probably do the 19 X 12 in the rear. That should get me a 325 tire. If they make 19 X 13 I will go for that. Then I could probably fit a 345.
Old Feb 4, 2011 | 04:44 AM
mcandrew67's Avatar
mcandrew67
You can fit a 345 on a 19x12 also as I had that set up on Z06 wheels previously.
Now I have 335's on a 19x13 set up.
To GS conversion wheel question
