Paint Chip Advice needed
Old Feb 6, 2011 | 10:27 AM
lucky1left's Avatar
lucky1left
Default Paint Chip Advice needed
Hi again all.......in attempting the 2400 mile road trip from hell cleanup...(from Museum delivery) I noted a very small, 1/16 or 1/8 " rock chip. It is right on the front of the hood edge and took a small divot. It shows white and your eye goes immediately to it. grrrrrr. I have no clue as to the remedy. ....buy touch up paint from Chev?....or what. It's Cyber Gray btw. Thanks for any advice.
Donna
Old Feb 6, 2011 | 10:45 AM
HOTSOSS's Avatar
HOTSOSS
I bought and used the Langka repair kit. It works with the touch up paint either from a dealer or other source, but not with the paint you would use to paint the car with. The problem with chip repair is using the touch up paint leaves a blob and the Lanka stuff makes it smooth. Follow their directions and over a period of several days, build the chip area up with several coats (I use a toothpick to dab paint into the chip area). Then use their blob remover to get it smooth. I have Crystal Red and the paint is difficult to match, but you should be ok with the grey. If this doesn't work for you, you can remove everything with the Lanka and take it to someone that specializes in chip repair. Good luck.
Old Feb 6, 2011 | 10:50 AM
lucky1left's Avatar
lucky1left
THANK YOU VERY MUCH. I'm a chicken, but on the other hand don't know of a good touch up artist. Anyone in Phoenix area have a recommendation?
Donna
Old Feb 6, 2011 | 10:51 AM
1FUNC5's Avatar
1FUNC5
also check out dr.colorchip.com
Old Feb 6, 2011 | 10:58 AM
Bandit1's Avatar
Bandit1
If you want to take the guess work out of it, go to your local Chevy or any dealer, find out who does their "touch up work" on used cars. Call the guy, set up an appointment and have the bumper/body panel of your choice done. It's usually between $25-$50 a panel to have them air brush the chips and then acetone off the over spay. It's invisible when done and a perfect match for the car. Why do you think the paint jobs are near perfect on the certified pre-owned vehicles?
Or there are a few DIY products:
http://appliedcolors.com/
http://www.langka.com/ (paint not supplied)
http://www.drcolorchip.com/
Old Feb 6, 2011 | 11:05 AM
Bandit1's Avatar
Bandit1
Donna
I know its a hike from Sun City to Tempe, but I highly recommend New Image. http://www.newimagepaintandbody.com/. They did work on two of my cars while I was stationed in AZ and both jobs were perfection. The owner is meticulous and uses nothing but oem parts for repair. After I purchased a used 99 C5, I had them touch-up the front bumper (pewter) and it was perfect. Its not too far off the 202 by ASU. Whoever you decide on for your repair, I highly recommend installing a clear bra after the repair; especially in that rock infested area of northwest Phoenix.
Old Feb 6, 2011 | 11:11 AM
lucky1left's Avatar
lucky1left
Bandit, thanks for the great info in both tour posts.
Donna
Old Feb 6, 2011 | 11:15 AM
Bandit1's Avatar
Bandit1
Donna
More than welcome, ma'am. Good luck with the touch-up repair. CG is a beautiful color.
Old Feb 6, 2011 | 12:45 PM
Rocketmanwpb's Avatar
Rocketmanwpb
I have used the used car touch up guy many times for my vettes' paint chips. Cost was as advised and you could not tell that the paint repair had been done. Only caveat is that you cannot do a repair to a horizontal surface such as the hood. Good luck.
Old Feb 6, 2011 | 01:44 PM
Red Rag Top's Avatar
Red Rag Top
Used it on a chip on my driver side mirror. left the paint blob set up for 48 hours and then worked it down to a smooth finish. Can't tell it was ever chipped
Old Feb 6, 2011 | 03:09 PM
surburban99's Avatar
surburban99
I use the Dr. Color Chip kit on my machine silver, with good results.
Old Feb 6, 2011 | 04:27 PM
LUVMINE's Avatar
LUVMINE
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
I had a 2005 Mag Red Coupe which got nailed by a passing truck. As soon as he passed me I knew I was in trouble. A rock caught the drvers side door right on the crease. Not to big but not to small either. I called the dealership from where the car was ordered. My salesman told me to call the local Mercedes dealer and ask them who fixes their cars when they're damaged. I did and they asked me to bring touch up paint and a case of their favorite beer. (Yungling) not spelled right
Bottom line, except for the beer there was no charge and they got rid of the damage. Couldn't tell it was ever there.
Hopefully there is someting in this story that helps you. Good Luck
Old Feb 6, 2011 | 05:14 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
To Paint Chip Advice needed
