The actual file names don't matter so much as the information in the ID3 tag -- that's where the information for the song is stored such as song title, artist name, album name, track number, etc. A big bunch of my MP3 files where retrieved from my iPod so they have cryptic file names of only four characters. For example something like "XXIP.MP3". But luckily when I retrieved the files from my iPod (long story...) they were restored to my computer in folders by artist and album names. Once they are displayed in either iTunes or some other MP3 player the info in the ID3 tag is what shows up. I burned six CDs filled with MP3s for my '10 GS's changer with no problem. I only made individual folders named by artist name -- each folder only has MP3 files of that artist. That makes finding stuff pretty easy if you know who you're looking for. And I have them in alphabetical order across the six disks. So Disk 1 will have stuff starting with "A" artists and the last disk probably has some ZZ Top on it. I have no trouble at all playing the disks nor is there a problem with the information showing up on my disk changer's display. It seems like the manual says that a disk can only have a maximum of maybe 25-29 folders -- not true! (Unless they meant NESTED, which I do not have any sub-folders.) Most of my disks have 30-40-50 folders because some artist folders may only have 2-3 tracks each. I think each disk averages about 150-160 MP3 files. No problem with my player!
Actually, the file name is more important. If your names are over 31 chars, you will have unexpected results in the way the songs play - which is what everyone complains about.
I changed nothing in my tags. Yes, the display only has 32 characters and it will truncate the title if longer than that in your tag. I consider that insignificant compared to having the names within the correct length parameter.
About the folders, and creating an MP3 CD - from the Nav manual (should apply for all CD systems). If you follow these rules, you WILL NOT have any issues:
Code:
Using an MP3
MP3 Format
When creating an MP3 disc, the following is a
list of guidelines. If these guidelines are not
followed while recording a CD-R(W), the CD
may not play.
• ID3 tag information is displayed by the radio
if it is available. The radio supports ID3 tag
information v1.0 or v1.1. The radio displays
a filename, song name, artist name, album
name, and directory name.
• Maximum 31 characters, including spaces, in a
file or folder name.
• Maximum number of folders is 500 with 500
files with a maximum hierarchy of eight
folders. It is recommended to keep the depth
of folders to a minimum in order to keep down
the complexity and confusion in trying to
locate a particular folder during playback.
• Create a folder structure that makes it easy
to find songs while driving. Organize songs by
albums using one folder for each album. Each
folder or album should contain 18 songs or
less.
• The files can be recorded on a CD-R or CD-RW
with a maximum capacity of 700MB.
• DVD with MP3 are not playable on this system.
• The radio does not play a mixed mode CD-R/RW,
a disc recorded with both *.cda and *.mp3
files.
• The player supports a disc with multiple
sessions, but it is not required that the disc
be finalized. It is recommended to record
the disc all at once.
• Recording format mode 2 or mode 2XA with
Romeo or Joliet file system is not supported
with this player.
• All applicable Mode 1 recording formats are
supported.
• MPEG 2.5 is not supported with this player.
File formats MPEG 1 and MPEG 2 with all bit
rates (including variable) except less than
16kbps are supported with this player.
• Long files or folder names or a combination
of a large number of files and folders could
cause the player to be unable to play up to
the maximum number of files or folders or
affect the reading speed and time to play.
USB Supported File and Folder Structure
The guidelines that must be met while
using USB supported files and folders are:
. Up to 699 folders.
. Up to 8 folders in depth.
. Up to 65,535 files.
. Folder and file names up to 64 bytes.
. Files with an .mp3, .wma, or .m4a file
extension. . AAC files stored on an iPod.
. FAT16
. FAT32
Some files may restart at the beginning
of the track after the vehicle has been
turned off and then turned back on again.
I've found the MP3s to be very inconsistent. There are always songs or folders missing no matter how few characters are in the name.
I appreciate the other responses with the suggestions, but the bottom line, it shouldn't have to be this way!
Bought a new Jeep. Has a hard drive AND a cool iPod connector. All the info I can't get on the Corvette, shows up on the Jeep. No change in files. Same data inputed. Jeep doesn't give a hoot about anything I ID'd. Reads it. Corvette? NO!
Now, if I had a several year old Corvette, I wouldn't compare it to a 2011 Jeep. But I have a 2010 Corvette.
Jeep was twenty grand less than my Corvette. GM, are you listening?
(ignoring Nav/usb port debate for a minute and looking at old school).... 6 cd in-dash changer for the Corvette from the factory msrp $399 (should be standard equip on non-nav cars at this price point)
25k Toyota truck...I upgraded upon ordering for better speakers, steering wheel controls and 6 disc in-dash changer - $210 factory msrp.
GM gets it all right..... and your wallet is what they get........
I've tried to burn music straight from my itunes on my macbook, but when I put it in the car, there are songs that are missing, or the car won't see it. But if I do it as a regular music cd it comes up fine. Is there a certain program that I can use for it to work properly? Roxio, etc? I would rather have 1 mp3 disk, instead of carrying my ipod in and out of the car. Any help would be greatly appreciated.
I have one CD that a certain .mp3 file causes the audio system to lock up. The only solution is to power down and back up. I haven't researched yet to see whether the problem is a long filename, corrupt file, etc., but I do know the CD played fine in other vehicles.
I also have an '09 Escalade with Nav, and it has the same filename and folder restrictions. Strangely, it has a tendency to display gibberish for the title, album and artist (first letter is right, the rest is symbols). Haven't seen this on the 'vette so I'm guessing the underlying software is different but the length restrictions are the same.
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
If that is what the manual says now it is correct. It used to say 32 characters. After extensive testing I found the limit is 25 valid character plus ".mp3" if you want consistent results. 26 and 27 works sometimes. 28 and above never work. The symptoms of file names that are too long is that the file disappears as far as playing is concerned but the player still knows something is there so it tries to play it. This results in the following file getting played and then repeated.
ID3 tags are irrelevant as far as creating a playable disc. They are only used for displaying the Title/Artist/Album. They must be version 1.x and not the more current 2.x version. Version 1.x ID3 tags are physically limited by the protocol to 30 characters. It is impossible to create a tag that is too long. If you try the software will automatically truncate the tag. Version 2.x tags are unlimited in length. You can, however, have both version 1.x and 2.x tags in the same file. So if you see more than 30 characters you are looking at version 2.x tags that won't display in the car. You need a program designed to show both tags to be sure you have the right version in the files.
The manual is wrong when it says you can use VBR (Variable Bit Rate) files. Yes, it will play them but with errors. Sometimes the song will quit early and you will not be able to fast forward or reverse consistently.
The free programs you need to quickly and easily create MP3s that work every time are:
Exact Audio Copy (with L.A.M.E.) to rip the music from CDs.
A.F.5 to manipulate filenames in groups although this isn't needed with a combination of ID3TagIt and Media Monkey below.
ID3TagIt to create the ID3 tags and also manipulate the filenames.
I have found that the ID tags do nothing except complicate things. The file folder name determines what is shown for artist and the mp3 filename shows the song title.
Well I guess that all depends if your music is tagged or not.
After performing the MP3 update, MP3 files, when selecting them through a list, were displayed by their actual file name. Albeit in ISO 9660 format (underscores instead of blank spaces, etc.).
When I had an issue with my NAV and had it replace under warranty, the new NAV seems to be reading the ID3 tag and using that information for the track listing.
I have to ask you. The picture you supplied is not in a C6 and why is there plastic on your NAV screen ?
Nope. Try it. Use folder and file names of just random characters and numbers and version 1.1 ID3 tags that have real Title/Artist/Album. What do you see? You see the ID3 tags for what is currently playing and the folder and filenames in the selection lists.
Yes, if you only have version 2.x tags and no version 1.x tags in the files, it can get confusing. If you create tags that it can read it shows them as it plays them.
That would be a fair comparison if the Corvette did the mundane things the Jeep does. If you bought your Corvette to compete with a Jeep you bought the wrong vehicle. Your Jeep will not corner as fast, will not accelerate as fast and has a top speed that is far less than the Vette's top speed. The Jeep doesn't have a forged aluminum double wish bone suspension at each corner, light weight compenents throughout the structure of the car or as powerful of an engine. If it had the structure and materials required to provide the performance of the Vette it would cost a lot more than what you paid for it. As the old adage says: "Speed costs money son, how fast do you want to go?"
Where do you want to spend your money? On the stuff that makes a car one of the top performing vehicles in the world or on something that doesn't really matter when you have your right foot to the floor, the wind blowing through your hair and the speedo is pointing at a number well north of 130?
I sure hope GM keeps listening to people like me and others who like to run our cars hard and enjoy the power of the vehicle and not people who don't seem to know what the car is built for.
