Insulation/Noise Reduction
Old Feb 12, 2011 | 08:31 AM
shelleygraham's Avatar
shelleygraham
Default Insulation/Noise Reduction
I have been seeing in catalogs kits for insulation noise reduction. Just wanted to know if they really work ? It is somewhat noisy with the roof up. If so, what brand and where can I get it. I see some have a complete kit, some the partition only. Thanks
Old Feb 12, 2011 | 08:35 AM
RadarP3C's Avatar
RadarP3C
Yes, most do make a noticeable difference. I have MadVette's insulation kit and highly recommend it.
Old Feb 12, 2011 | 08:46 AM
shelleygraham
Thanks, does a vendor carry it ?
Old Feb 12, 2011 | 09:13 AM
RadarP3C's Avatar
RadarP3C
Yes, MadVette Motorsports.
Here is the link on his website for the insulation kit ...
http://cca.madvettemotorsports.com/s...ct_detail&p=99
Old Feb 12, 2011 | 10:25 AM
cmonkey713's Avatar
cmonkey713
The pre cut kit would be the easiest way to go and provides good results. If you want to go to the next level there are several insulation products made specifically for various parts of the car. DynaMat , is most likely the industry leader but also the most expensive. They have a product for floor-pans and other panels in various thickness and costs. This stuff is not cheap but it will make a Corvette quite like a Lexus if that is what you are after. I have a friend who has a C-6 coupe with a B&B cat-back, long-tubes and high-flow cats and it is as quiet as a tomb inside the cabin. Your time and labor are a big issue which will be about the same no matter what product you use. It's just like anything else on these cars, what level of performance do you want and how much do you want to spend. Seriously consider the "Kit" but if you need more db reduction there are other options you can use in addition the the kit insulation.
Old Feb 12, 2011 | 10:33 AM
budgreen3564's Avatar
budgreen3564
Block It from TKO Performance and get rid of the OEM Goodyears
Old Feb 12, 2011 | 11:10 AM
corvettemods1's Avatar
0corvettemods1
Former Vendor
St. Jude Donor '12-'13
Our Ensolite kits do the trick and are computer cut, not hand cut for perfect fitment!
http://www.corvettemods.com/servlet/...ette-c6/Detail
Old Feb 12, 2011 | 11:14 AM
johnodrake's Avatar
johnodrake
Moderator
Ditto
Old Feb 12, 2011 | 11:28 AM
RadarP3C's Avatar
RadarP3C
And not only does it include the door panels, but also the cabin floorboards and tunnel area in the cabin.
Old Feb 12, 2011 | 11:39 AM
Bandit1's Avatar
Bandit1
I'd recommend talking to "RAAMaudio", aka Rick (Forum Vendor) before you make any decisions for purchase. Knows the business and technical/performance aspects and takes care of his customers.
Old Feb 12, 2011 | 11:54 AM
gaphono's Avatar
gaphono
Madvettes is a great product. Reduced my console heat and noise levels. I had them install the Insulation in my car.
Old Feb 12, 2011 | 12:26 PM
phileaglesfan's Avatar
phileaglesfan
I went with Crazy Cowboy at exoticvette.com. http://www.exoticvette.com/insulation%20c6.htm
My car is the one in the video. I installed it about 2 1/2 years ago with another member (46490). We also installed it on his Vette and a friend's Z06.
It makes the car feel real solid and reduces tunnel heat dramatically. It probably reduces noise about 3 db.
Feel free to ask me any questions about installing it. I would help you out for free if you lived near Salt Lake City.
Old Feb 12, 2011 | 12:59 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Block-it is a must have mod for the C-6!
Old Feb 12, 2011 | 01:11 PM
vetteright's Avatar
vetteright
Highly recommend the Madvettes kit. It has done the job for me. Really quiet now and the heat reduction has been outstanding.
Old Feb 12, 2011 | 04:34 PM
KneeDragr's Avatar
KneeDragr
Id get the one you dont have to rip the carpet out.
Just forgot which one that is!
Old Feb 12, 2011 | 04:48 PM
TKO Performance's Avatar
TKO Performance
Premium Supporting Vendor
Active Streak: 90 Days
From: ★ Performance Parts & Accessories ★ 1800 778 9898
St. Jude Donor '07-'08-'11-'12-'13-'14-'15-'16-'17
Read about it hear:
Coupe-http://store.tkoperformance.com/bleadinnodes.html
Convertible-http://store.tkoperformance.com/bleadinnodes1.html
If you do a search there are a good number of posts and threads with positive comments
Old Feb 12, 2011 | 08:15 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
That's what we did, better tires and quieter inside. Easy to do, but ya gotta write a couple of checks.
To Insulation/Noise Reduction
Old Apr 17, 2011 | 12:40 PM
veni vidi vert's Avatar
veni vidi vert
Hey Radar. (or any of you with the MadVette's kit).
Do you have the regular or premium layer? I'm trying to figure out which one to order.
Thanks,
Old Apr 17, 2011 | 12:53 PM
gunterwalker's Avatar
gunterwalker
From: Cape May, NJ; Guntersville, AL; Orange Beach, AL
I'm looking into a sound deadening kit but from everything I have read I'm not getting my hopes to high. The kits work great for heat though but for sound I have read that it helps some but many wish they would work better. Can't have your cake and eat it too.
Old Apr 17, 2011 | 02:23 PM
Lubrecon's Avatar
Lubrecon
Check out Second Skin Audio. Their material appears to be the some of the most technically competent material I have seen. Their Damplifier Pro and Luxury Liner Pro are used by many custom car builders. I have purchased that, but have not received it as yet. When I get it insatalled, I will report of the results I get.
