Wheel Removal
Old Feb 13, 2011 | 05:46 PM
cgeaves's Avatar
cgeaves
Default Wheel Removal
I know I'll get flamed for this but I can't remove my rear wheels. All five nuts are off and I swear I could drop the car right now and run it and I don't think the wheels would come off. Any suggestions on how to break them loose?
Old Feb 13, 2011 | 05:53 PM
Blaq Ops's Avatar
Blaq Ops
Is it off the ground? Is it cocked or wedged? Make sure it's level and pull it straight off.
Old Feb 13, 2011 | 05:56 PM
Bobs11GS's Avatar
Bobs11GS
If you have rubber mallet, hit it a few times at different areas of the tire. It should break loose.
Old Feb 13, 2011 | 05:57 PM
CO Lightfoot's Avatar
CO Lightfoot
Is the wheel off the ground?
... sorry, couldn't resist.
I don't know for sure, but does the parking brake prevent it from removal?
cmonkey713's Avatar
cmonkey713
Sounds like the wheel may be rusted to the rotor face. I would get a large rubber mallet and tap it them from the inside to break the wheel loose. If you don't have a mallet you can use a 2X4 and a 2 pound metal hammer to hit the 2X4 from the inside. You could also use some penetrating oil spray where the back of the wheel hub contacts the face of the brake rotor and let it work for a while before using the mallet.
I can't imagine anything else that would be holding the wheel on. The 5 lug nuts are the only thing that holds it on.
Old Feb 13, 2011 | 06:15 PM
cgeaves's Avatar
cgeaves
I only have a small rubber mallet and I've pounded with that....no results.
I guess I'll try a 2 x 4 and regular hammer from the inside. Crazy!
Old Feb 13, 2011 | 06:20 PM
GMJim's Avatar
GMJim
If the rubber mallet doesn't work, cover the wheel with a beach towel (so you don't scratch the rim) and sit on the ground (or stand with your back to the wheel) and hoof it on the right then left until it comes off. Put a couple of the nuts on almost all the way so the wheel doesn't fall off and get scratched. Then clean the corrosion off and apply a little anti seize on the hub area (not on the threads) so it won't happen again. I've had them seize so bad that I had to put all the nuts back on within a thread or two of all the way and drive the car and nail the brakes to free the rim from the hub.
Old Feb 13, 2011 | 06:42 PM
airbill2's Avatar
airbill2
How about seeping a little penetrating oil around the studs and flange. If you get any on the brake be sure to clean it with alcohol.
Old Feb 13, 2011 | 06:47 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
both good ideas below. it's just that the wheel has gotten slightly stuck to hub. just take it easy when pushing on the tire with your feet---you don't want to bend/break a stud. or as said, have the wheel fall off.
and if you use the penetrating fluid, it's a bit tricky not to overspray toward rotors. I'd try the "mechanical" foot method first.
Old Feb 13, 2011 | 06:51 PM
LMB-Z's Avatar
LMB-Z
Lie down in front of the wheel (facing the wheel) and kick the tire on each side of the rim. Should break it loose.
Old Feb 13, 2011 | 06:53 PM
cgeaves's Avatar
cgeaves
OK, I got it. It was just rusted onto the rotor. About eight or ten kicks with a right leg from the inside did the trick!
Old Feb 13, 2011 | 06:56 PM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
I can't beleive it was that rusted on!!
At least you got it done.
Old Feb 13, 2011 | 06:59 PM
VET4LES's Avatar
VET4LES
Old Feb 13, 2011 | 07:00 PM
kevakasper's Avatar
kevakasper
2017 C4 of the Year Finalist
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
Tighten one side again, and on the other, put the lug nuts on, but loose, maybe a turn or two loose, let the car down onto the ground again, and rock the car side to side. the wheel should break free. Repeat on the other side. I had to do this on my van and they were a B$%#h. But it worked, and I then coated the hub with antisieze, and last time I took them off they removed without a problem. Always torque your lug nuts to 100 ft. lbs. with a torque wrench in a star pattern.
Old Feb 13, 2011 | 07:05 PM
LUVMINE's Avatar
LUVMINE
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
Another happy ending. That's why I love the Forum.
Old Feb 13, 2011 | 07:09 PM
cclive's Avatar
cclive
I'm betting he doesn't live in a dry area of the country....
Old Feb 13, 2011 | 07:25 PM
GMJim's Avatar
GMJim
Glad to hear you got it off. You could have kicked it from the outside though. Recently had a 2005 Mustang in with all four wheels seized. Took the car out and at 20 MPH needed to hammer the brakes to a complete lock up 5 times to snap the wheels loose. Not the worst I've seen though. I remember cutting a rim off of a 78 Ford LTD with a torch because all other methods failed. Aluminum and steel mixed with road salt equal big trouble if not lubricated.
To Wheel Removal
Old Feb 13, 2011 | 07:42 PM
Bill Dearborn's Avatar
Bill Dearborn
I was going to say put the lug nuts on and let them be a turn or two from tight and the drive the car for about 50 ft while turning the steering wheel from lock to lock. That should put enough force on the tires to break the wheels loose. Have had to do this sometimes to remove brake rotors on the Tahoe. Sledge hammer wouldn't move them. Put wheel on loosely and drove around in circles and the rotor popped loose.
Bill
Old Feb 13, 2011 | 07:53 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
An engineer once said we should never use anti-seize on the hub area, because what really keeps the wheel from moving around is the clamping action of the lug nuts that forces the wheel against the hub . Because of this clamping, the actual forces of driving are taken by the hub area and not by the studs. He said that using oil or anti-seize on the hub will greatly increase the stress on the studs, and can lead to stud breaking.
No personal way to know if this is correct, but it sounds like a logical possibility. People do use antiseize without problems, but maybe it's not a good idea.
Old Feb 13, 2011 | 09:02 PM
cmonkey713's Avatar
cmonkey713
Yep! the only thing that it could have been was rusted on. Like I said in the post "there is nothing else that holds the wheel on but the 5 lug nuts". Before reinstalling the wheels be sure that you clean all the rust off of the wheel and the rotor, then just use dome WD-40 or such so it won't happen again.
