c6 alignment
Old Feb 14, 2011 | 03:13 PM
gunone's Avatar
gunone
Default c6 alignment
anyone have any ideas on when a good time would be to check my alignment? im changing tires and just thought it would be easy to do it now.the old tires look fine and the car drives excellent .would i be wasting my money and time?
Old Feb 14, 2011 | 03:21 PM
tim414's Avatar
tim414
St. Jude Donor '12
now is best time to have it checked. Won't cost as much checking. If they do end up doing a alignment then you pay for that. if just check should be less.....
Old Feb 14, 2011 | 03:26 PM
SWright's Avatar
SWright
Had a 2000 C5 for 9 years and 74,000 miles and never had an alignment done. As I saw it if the tires are wearing evenly and are lasting what is considered reasonable mileage (24,000 miles) I didn't think an alignment was necessary. That being said the front tires on my 08 C6 lasted 20,000 miles and were wearing just a tad more on the inside, rears were wearing evenly and had about another 4000 miles worth of tread on them. Had all 4 replaced and had a front end alignment done. Tire merchant had a readout of before and after alignment. Front was out a good bit. Bottom line if my tires were wearing evenly I wouldn't have an alignment done.
Old Feb 14, 2011 | 03:31 PM
SWright's Avatar
SWright
Tim414 has a good point. My tire store will check alignment for nothing.
Old Feb 14, 2011 | 04:09 PM
Larry/car's Avatar
Larry/car
If the handling and tire wear are good, don't mess with it.
Old Feb 14, 2011 | 07:07 PM
Vettin08's Avatar
Vettin08
Have it checked when they put the new rubber on.
Old Feb 15, 2011 | 06:26 AM
gunone's Avatar
gunone
true. but chances are that if they take the time to check it they will find something wrong with it dont ya think?
Old Feb 15, 2011 | 06:37 AM
BostonJoel's Avatar
BostonJoel
My rule of thumb when I put new tires on any car.
Hutch45's Avatar
Hutch45
Wounded Warrior Escort '11
Personally, I would have the alignment checked on all fours upon installing new tires. It is worth the money to prevent future tire wear.
My 2 cents only.
Old Feb 15, 2011 | 07:34 AM
1fastbob's Avatar
1fastbob
If tires look good, I'd leave it alone. If it ain't broke, don't fix it.
Bob
Old Feb 15, 2011 | 08:22 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I like the concept of, if the tires are wearing ok, leave it alone. Only trouble is, what looks to be ok, isn't. As swright said above, he got 20K out of his front tires, and when putting on new ones, did an alignment only to find out the front was "...out a good bit." Tells me he could have gotten more out of his tires at $200-$400 each if he'd had an alignment.
Yes, when checked (kind of like the old "headlight needs adjustment" whenever it's checked) usually something WILL need adjustment. Wonder why.....
Maybe it's because an alignment can go out a little or a lot (like swright's) the day after you get one done---RR tracks, big bump/pothole, curb, etc..
Or it could happen two years down the road. Thing is, it's a regular maintenance item that you can choose when to have done. Sooner, and you don't have to get those $200-$400 tires quite as soon, maybe another 4K miles on them which is another 20% (which is what swright got on his rear tires). Later, and you do have to get them sooner.
You decide what it's worth to you.
Old Feb 15, 2011 | 08:42 AM
GSRANDY's Avatar
GSRANDY
I had the front / rear alignment checked on my 2010 GS at 1,000 miles.
The alignment was found to be out of tolerance on all four (4) corners.
To maximize tire tread life, I had the tech set all four (4) corners to the mean as my GS is a non-tracker, sunny day driver.
Regards,
GSRANDY
To c6 alignment
