I need to find some thin wheel spacers for my '05 coupe. Only need 2 - 2 1/2 mm, or about 3/32 inch. Everything I'm finding online is thicker than that and needs longer studs. I don't need that much. Just a teensy weesie nudge off the calipers.
Can anyone help me with this? Point me in the right direction? Would be very much appreciated.
You could try extended thread lugs instead of replacing the studs. I've seen posts from other forum members who run spacers with ET lugs although I would not run ET lugs with spacers larger than 1/4".
Another option http://forums.corvetteforum.com/c6-p...f-members.html. They're pricey, but it is another option (approximately $110 for 20 short lugs shipped). You would need to contact the vendor for an exact quote with shipping to your zip code.
I run 1/4" in front and 3/8" in the rear. I had the studs replaced with ARP 1/2" to be on the safe side. The ARP 1/2" studs are not much longer than OEM studs. When I had the studs replaced, the mechanic and I checked to make sure the lugs were not bottoming out. I could run with or without spacers using my 5 spoke OEM wheels and the ARP studs.
