I had my Vette tuned a couple years ago by a very well known tuner and I notice he bumped the rpm limiter to 7100rpm's. It was explained to me this is done to keep fuel from being shut off. Is this a problem for the LS3? (valvefloat,etc). I honestly am not sure.
If it were my car, I wouldn't raise the rev limiter above GM's stock value unless I was very sure what improvements were made to the engine that would allow it to rev higher. If the motor was rebuilt with better valve springs, lighter valves, stronger connecting rods, and lighter pistons, and the builder stood behind their work, then I'd consider raising the rev limiter. If you haven't strengthened the engine, then in my opinion, you're asking for trouble down the road.
I had the limits completely removed (and the tables rebuilt) on my ls2 almost 5 years ago and have never had any negative issues. On the positive side, that annoying limiter doesn't pop in at the worst times and screw up my accelerations - almost caused me to crash once!
What!! The other guy almost rear ended you??
I have hit the 7K rev limiter in my Z in all the gears up through 4th and did the same with my two C5s and their rev limiters. Never disturbed any of them. All they did was stop accelerating like they would if they didn't have enough power to twist any more.
Thanks guys. I wonder why nobody has brought this up before as one of the biggest tuners on here did the work? Why would this be accepted on so many cars if it could be a prob. Maybe it's simply not a problem?
By the way, he isnt the only tuner that does this.
There have been numerous discussions about the rev limiter nanny and the pros/cons of tunes that modify it. Use the SEARCH utility at the top of the page
What other guy? Sorry, I don't know what you're talking about.
Woosh over the head!!!
The only reason I could think of that you would have an accident would be the car slowed and the car behind you almost hit you. The rev limiter doesn't cut in in such a way that you should have trouble controlling the car other than slowing down.
Bill
Difficult to remember the actual circumstances being that I did the tune years ago, but hypothetically I'll say that if I was accelerating into a difficult turn and that damn nanny killed my power, I would certainly loose quite a bit of control. Like I said, can't remember what the exact incident that made up my mind to get rid of that nanny, but I do know that the rev limit points bugged the crap out of me for quite a while before I finally god rid of them. Problem solved.
I should say that I have an aftermarket trans that is tuned for long pulls between shifts. The rev limit points needed to sync with the tune, but were difficult so in the end it was easiest to eliminate them.
If you're the type of driver that rarely hits the rev limit, then I guess it wouldn't seem to be an issue for you. For me it was.
Reason: fix typo
Bill
Reminds me of the posts about AH almost causing an accident so it always gets turned off. I've hit the rev limiter mort times then I can count but never on public roads. If you're hitting it on public roads I would suggest you're driving recklessly and the rev limiter is the least of your concerns.
Rev limiter causes your car to gently slow down due to fuel being cut off. Losing control involves loss of traction. I don't see one causing the other.
