Replacing wheel speed sensor?
Old Feb 28, 2011 | 10:43 AM
FloydSummerOf68's Avatar
FloydSummerOf68
Default Replacing wheel speed sensor?
Quite frankly, I have no idea what is involved.
I believe at least one of my wheel speed sensors has gone bad because at any given time after starting to drive my car (usually within 1-2 minutes) the AH, ABS and Traction Control all light up saying they need service.
Also usually during my first braking after starting the car I get physical push-back from the ABS system (but never again during that time driivng).
Because all three are going off at once I believe it is probably a wheel speed sensor since all three reference that.
Where exactly is the sensor located?
Is there any way to determine which sensor is bad?
How do I inspect/repair/replace it?
Thanks for your help!
Old Feb 28, 2011 | 10:56 AM
RicK T's Avatar
RicK T
Seems unlikely, they're pretty reliable. If one was bad you should get a MIL. Get a code reader on it, bad Wheel Speed Sensor circuits should return C0035, 40, 45 or 50.
Old Feb 28, 2011 | 11:33 AM
FloydSummerOf68
Well perhaps it's just a poor connection (which I've read about a lot with corvettes).
Old Feb 28, 2011 | 11:34 AM
cclive's Avatar
cclive
The wheel sensors are really just an LED, so are pretty reliable. If you do need to replace though, it is very easy. A nut or two and a plug...piece of cake. With all those warnings, you need to get a code reader on it. I'll bet it is not something serious...usually, the bigger the failure, the easier the diagnosis.
Old Feb 28, 2011 | 12:09 PM
FloydSummerOf68
Well I'll check em out this weekend.
It seems like it's pretty common for the female end to be causing a bad connection and need to be bent down a bit.
If that still doesn't fix it I'll take it somewhere to read the codes.
Old Apr 4, 2011 | 12:12 PM
SCRMNC5's Avatar
SCRMNC5
You can easily check them yourself
http://www.stengel.net/diccodes.htm
Old Apr 4, 2011 | 12:28 PM
cclive's Avatar
cclive
Do you regularly telescope the wheel in and out? If so, I would bet on the harness on the column over a wheel sensor...
Old Apr 4, 2011 | 12:51 PM
FloydSummerOf68
Has nothing to do with that. Mine doesn't have a telescopic wheel
Old Apr 4, 2011 | 12:53 PM
FloydSummerOf68
Cool info if it also works on the C6
Old Apr 4, 2011 | 01:19 PM
cclive's Avatar
cclive
That code info only works on C5s. You can go to almost any parts store and they will hook up their reader and give you the codes for free though.
Old Apr 4, 2011 | 03:20 PM
FloydSummerOf68
Yeah, I assumed it was C5 only.
Anyway, I'm just going to use a multimeter to figure out which sensor is giving me problems and I'll go from there.
Old Apr 4, 2011 | 03:56 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
I had a wheel speed sensors replaced on my C5 more than once. It's not unlikely at all that they go bad.
Old Apr 4, 2011 | 06:01 PM
Bill Dearborn's Avatar
Bill Dearborn
Even if he had the telescopic wheel it still wouldn't be in consideration. That part doesn't affect all 3 functions of the ABS system. The parts that affect all 3 are limited.
To the OP:
You can't just go around throwing parts at the car or it will get expensive very quickly. You need to find somebody with a scanner that car read the ABS codes. Probably won't find that at AutoZone or Advance Auto. If it is a sensor or the wiring to the sensor the codes will lead you to the correct area. By the way the sensor is part of the wheel bearing and is replaced by replacing the wheel bearing. It isn't an LED like mentioned in a post above. It is a Hall Effect sensor.
Bill
Old Apr 5, 2011 | 08:10 PM
cclive's Avatar
cclive
That's right...I was thinking about those ambiance LEDs when writing that...it is a hall effect (magnetic) sensor...oh well, LEDs, schmeLEDs!
Old May 24, 2012 | 08:51 AM
OctagonMan's Avatar
OctagonMan
Default Help me get to the Bottom of this
I'm experiencing this exact same problem with my 2007 C6.
Car is at Dealer, but they don't seem to have clear indication of the cause.
How did you fix your problem?
Any Helps will be greatly Appreciated!
Old May 6, 2016 | 06:33 PM
nbergma's Avatar
nbergma
Cruising
I had the same 3 codes on my 2006 C6 Corvette:
Service Anti-lock brakes
Service active handling system
Service traction control system
The Chevrolet dealership (Michael Chevrolet in Fresno, California) said they had to replace the left front hub because the speed sensor was bad. $850. But the problem is now fixed.
And my bank account is considerably light. :-(
Old May 6, 2016 | 06:42 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
Eight fitty ??? Daaaaaaaaaayum !
To Replacing wheel speed sensor?
Old May 7, 2016 | 09:40 AM
C6ToGo's Avatar
C6ToGo
So glad I learned how to turn a wrench. That is a $40 repair with a no-name bearing and a couple of hours of your time.
Old May 7, 2016 | 10:03 AM
Dcasole's Avatar
Dcasole
I agree , even if u use a good bearing it's not that much
Old May 7, 2016 | 11:31 AM
need-for-speed
CI 1-4-5-8-9-10 Vet
Good to know in the event that one of mine fail. I got mechanic skills too.
