Positive Battery Cable
Scrub the battery terminal and cable with a solution of baking soda and water. This will neutralize the acid. Wipe with a clean rag and let dry.
After it dries, reconnect it to the battery and spray the battery post with white lithium grease. This will prevent moisture in the air from oxidizing the lead battery post and connector.
post where it does not have a proper seal. I searched the web last year on this problem and that is what I found. The reason for that was my wife's Lexus had the same issue including having the battery clamp eaten thru. The dealer replaced both the battery and the battery cable under warranty, no charge.
If you regularly use a good battery maintainer (like a CTEK), it almost doesn't matter which replacement battery you use... the maintainer will keep it well-charged. Then you can shop for the cheapest battery that fits.
Some folks shop for the best price at Costco, Walmart, etc.
Some folks, like me, have gotten great service from the OEM Delco battery.
Some folks love Optima batteries... red or yellow, depending on your needs. IMO this gives extra peace-of-mind -- at a price.
Some folks will only buy a Sears battery... in my mind, they have a deserved reputation for great service & warranty, and IIRC their Platinum series is highly rated.
Cost-no-object Odyssey battery thread (with great install details):
http://forums.corvetteforum.com/c6-t...-c6-coupe.html
But that Odyssey weighs 49 lbs and costs $258... 12.5 lbs and $50 more than an Optima.
Bottom Line: Decide what YOU need and how much you're willing to spend. And for peace-of-mind & max battery life, regularly use a good battery maintainer -- especially if your C6 is driven infrequently and/or mostly short distances.
That was a great link he provided from Klaus-96; Is this a great forum
or what?
When it comes to tires and batteries I simply choose to go with what I think is the very best. The operative words being - "I" and "choose". Getting stranded for the failure of either of the commodities is something I try very hard to avioid.
In selecting a Vette, if I had thought the most expensive was the "best" I would have choosen a ZO-6, ZR-1 vs. the base; so I well understand cost comparisons may or may not always apply. No offense to you ZO-6, ZR-1 folks.
