Convertible Top
Old Mar 6, 2011 | 01:19 PM
nikic6's Avatar
nikic6
Default Convertible Top
The water on the convertible top of my 2011 C-6 really beads up. Is there anything I need to put on the top to keep the top water proof? Is it best to just leave it alone?
Old Mar 6, 2011 | 01:25 PM
vettedoogie's Avatar
vettedoogie
I would leave it alone until you start noticing it not beading up. Then you MAY want to look at using RaggTopp to clean and treat it.
http://www.autogeek.net/racotopcakit.html
Old Mar 6, 2011 | 01:32 PM
cclive's Avatar
cclive
Scott, the 'Bugman' has a great site with lots of good info. He has pics and info on the convertible top and how the water beads up. Look under "RaggTopp" on the left side.
http://www.bugmanweb.com/c6/c6index.html
Old Mar 23, 2011 | 12:57 PM
Icebear's Avatar
Icebear
Old Mar 23, 2011 | 01:03 PM
larryrs's Avatar
larryrs
Be sure to use it on a calm day or use painters tape on the glass around the top. I really had a tough time getting that dried RAGGTOPP chemical off my front and rear glass.
Old Mar 23, 2011 | 01:12 PM
TexasMadMan's Avatar
TexasMadMan
Water beading is a good thing.
Old Mar 23, 2011 | 01:23 PM
elsilva's Avatar
elsilva
Has anyone tried the 303 Fabric Convertible Top Kit, Aerospace Protectant? If you have what do you think of the product, I have a friend that swears by it.
Old Mar 23, 2011 | 02:25 PM
BlackBull172's Avatar
BlackBull172
Leave it be-----perfectly normal with all convertibles (not just vettes)
If it bothers you that much, after it rains just wipe it down with a soft rag---
Now stop worrying, and enjoy that beautiful car!
I currently have a Mustang GT vert (same fabric style top) Its normal (trying my hardest to get into a Vette, but as always money is ALWAYS an obstacle for me)
Old Mar 23, 2011 | 03:28 PM
Sunnyvale Dave's Avatar
Sunnyvale Dave
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'19
I use 303 products, but I use fabric guard for the top. The Aerospace Protectant is not designed for the material Corvette tops are made of.
Old Mar 23, 2011 | 03:35 PM
cclive's Avatar
cclive
The convertible Mustangs that I have seen use a vinyl fabric, not canvas like the Corvette. Different protectant would be needed.
Old Mar 23, 2011 | 03:39 PM
keyplyr's Avatar
keyplyr
IMO just leave it alone. Every time you put chemicals on a surface, especially something a convertible top, it has a reaction which alters the original make-up. I try to avoid chemicals wherever possible.
Over 6 years with no chemicals and my top looks great and water beads up just as it was new. I do keep it clean with a fabric brush and never put it down dirty.
legbuh's Avatar
legbuh
I used Raggtop on my Z4.. and will use it on the Vette.. but only once every couple of years. You need to make sure you do the proper cleaning before applying it. Using a large sheet or blanket to cover the front/side windows works great too, then just tape up the rear window and cover the rear with another blanket and spray away.
Old Mar 23, 2011 | 06:27 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Since I use my Vette year round, I apply RaggTopp every spring. So far my 2006 top still looks brand new.
Tom
Old Mar 23, 2011 | 09:27 PM
jimhild's Avatar
jimhild
We have used this on four different tops, two Corvettes a C5 and our
C6, The Thunderbird Convertible and the Solara Convertible. Worked great on all of them. Really makes the water bead up and flow off.
I think the NCM still stocks and sells these products a cleaner and a sealer.
Good stuff.
Old Mar 23, 2011 | 09:29 PM
VetteMark's Avatar
VetteMark
too!
Old Mar 23, 2011 | 10:01 PM
keyplyr's Avatar
keyplyr
I forgot to mention that every once in a while I use a shop vac to really get the top clean, and of course I keep the entire car covered when not in use.
Old Mar 23, 2011 | 10:04 PM
GotChrist?'s Avatar
GotChrist?
Vacuum, wash, then treat with Ragg Top or 303 FABRIC protectant.
To Convertible Top
