Jack Stands
Old Mar 9, 2011 | 01:36 AM
Rossi6998's Avatar
Rossi6998
Default Jack Stands
I am in the process of researching Jack Stands to use on my C6. What should I look for with regard to brand and size (2 ton, 3 ton, etc.?)
Old Mar 9, 2011 | 02:13 AM
CO Lightfoot's Avatar
CO Lightfoot
2-ton works fine.
Great info on Bugman's site:
http://www.bugmanweb.com/c6/c6index.html
(See "Jack" in the INDEX )
Lots of pictures & instructions & tips.
Old Mar 9, 2011 | 05:58 AM
KarlK's Avatar
KarlK
From: Beats UD regularly playing 3D chess, and at life
I've used these for years;
http://www.northerntool.com/shop/too...3386_200313386
Old Mar 9, 2011 | 08:27 AM
Top_Fuel's Avatar
Top_Fuel
Not cheap, but the only flat top jack stand I've seen...
FLAT TOP JACK STANDS
^ These are a copy of the well-known, but no longer available, AC Hydraulic Jack Stands.
Old Mar 9, 2011 | 09:26 AM
Xedes's Avatar
Xedes
These are very nice! I've never put a car up on jack stands. Is it pretty easy? Is the best spot for jack stands the location where the jacking pucks go or somewhere else? Are four stands a should have or will two get most jobs done? Thanks and I hope this isn't hijacking the OP's thread.
Old Mar 9, 2011 | 09:28 AM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
I have a set of four of Craftsman 3 ton High Rise jack stands. If I were to buy again, I'd go for a shorter 2 ton model. It is difficult to get the rear of the car high enough to use them.
It really is pretty easy to get the car up on stands. Most everything can be done on two, other than changing rear end oil. This weekend was the first time I had ever gotten my car up on four honestly, and it was because I changed my diff fluid and put on my headers. Check out This site which CO Lightfoot mentioned earlier. It has really good info.
Old Mar 9, 2011 | 09:39 AM
C6FirstVette's Avatar
C6FirstVette
Got rid of the heavy steel four legged type and went with aluminum ones and work great and extremely well made>>>
Old Mar 9, 2011 | 10:06 AM
Top_Fuel's Avatar
Top_Fuel
Check Bugman's website. He's got a lot of info and diagrams that will answer your questions.
Old Mar 9, 2011 | 10:12 AM
KX's Avatar
KX
You are in Calif....go to any Harbor Freight. Yes, inexpensive, but hey, you do not need to spend a lot on these.
Old Mar 9, 2011 | 10:14 AM
Top_Fuel's Avatar
Top_Fuel
Matco sells a "quick to load" jackstand. You slide it under the car, lift up on the locking mechanism with one finger, and the top part of the jackstand extends automatically. Pretty cool idea. Here's what it looks like (this is Snap-On's version of the same thing)...
Matco Part # JS6QL
Old Mar 9, 2011 | 10:20 AM
gunterwalker's Avatar
gunterwalker
From: Cape May, NJ; Guntersville, AL; Orange Beach, AL
I have a set of the 2 ton and the 3.5 ton stands. they are the same except for load limits. I use the 3.5 on the front and 2 on the rear. Hope this helps.
Old Mar 9, 2011 | 02:30 PM
Xedes's Avatar
Xedes
The flat ones seem more suited for the jacking pucks. Is there a different location for placing the ones with the curved ends?
To Jack Stands
