im looking at a 08 base vette with all z06 body. if i wanted the z51 braking would i only need rotors cals and pads. if so about how much is that and is it worth doing. if i bought this car i would probably mod it very lil if that matters.
Total kit with all four rotors and caliper brackets - $561.00
Use part number c6z51brakes on the website to order this kit.
You might be able to find someone in the Parts For Sale section with "take off" Z51 brakes but you would need to be careful not to get damaged or abused parts. Good luck.
I did it on ours only because I had the caliper brackets sent to me accidently when I did powder coating, otherwise I would have just purchased stock size drilled rotors
You only need to add Z51 brackets and rotors... if your interested in a set we can take care of this for you... here's a conversion we did for a customer with our powder coated calipers.
__________________
TPSMotorsports.com Mike Mak 2705 Lafayette Street
Santa Clara, CA 95050
Phone #: 408/898-4632
Email #: MikeM@TPSMotorsports.com
