power window not working
Old Mar 13, 2011 | 11:56 PM
mach1daddy's Avatar
mach1daddy
Default power window not working
Power window for driverside window does not work, passenger works just no driver, any tips anyone, thanks.
Old Mar 14, 2011 | 02:02 AM
Blaq Ops's Avatar
Blaq Ops
Can you hear the motor or just silence? How old is the car?
Old Mar 14, 2011 | 10:15 AM
mach1daddy's Avatar
mach1daddy
it make a little click, the car is a 07.
Old Mar 14, 2011 | 10:18 AM
RicK T's Avatar
RicK T
Are the doors closed? Are you still trying to deal with the pwr top?
Old Mar 14, 2011 | 11:44 AM
mach1daddy's Avatar
mach1daddy
I installed new speakers in door, battery died, top was down. manually put top up. but driver window won't go up.
Old Mar 14, 2011 | 11:53 AM
RicK T's Avatar
RicK T
That's why I asked if the doors are closed. It has happened to quite a few people. They leave the door(s) open while working on the car, the battery dies then they can't get the top up because the windows aren't indexed and they can't index the windows because they are trying to do it with the door(s) open.
My recommendation is, with the battery charged or replaced, get in, close the doors then re-index the windows then the top will work.
Old Mar 14, 2011 | 11:56 AM
mach1daddy's Avatar
mach1daddy
yes, I understand that, but what about the driver door window? I need to fix that before re-indexing.
Old Mar 14, 2011 | 12:01 PM
RicK T's Avatar
RicK T
Okay, we aren't communicating well here.
1st- Are you trying to operate the window with the door open?
Old Mar 14, 2011 | 12:05 PM
jaki30's Avatar
jaki30
Default Happened to me
I had disconnected the battery on my 07 vert. When I went to re-index the windows, the passenger side worked, not the drivers side.
I had to close the door with the engine running to allow the window to operate. Don't ask me where they came up with this sequence, but, the window only worked after I closed the door!
Old Mar 14, 2011 | 12:11 PM
mach1daddy's Avatar
mach1daddy
yes trying to operate with door open, sorry if you are not understanding me. thank you very much for your help.
Old Mar 14, 2011 | 12:27 PM
RicK T's Avatar
RicK T
Okay, so just get in, CLOSE THE DOOR(S) and everything should work from there on.
Old Mar 14, 2011 | 12:43 PM
mach1daddy's Avatar
mach1daddy
thank you very much.
Old Mar 14, 2011 | 02:13 PM
mach1daddy's Avatar
mach1daddy
ok windows work, top did work. to test I put it down and then back up. but the body cover would not come back down. I released the pressure on the hex nut power top but the body part is still up in the air and won't move.
Old Mar 14, 2011 | 09:38 PM
mpuzach's Avatar
mpuzach
Did you complete the window indexing process?
To power window not working
