View Poll Results: When did you change your factory installed battery due to failure? (Stock Only C6's)
Before 1 year
8
3.96%
Between 1 and 2 years
17
8.42%
Between 2 and 3 years
23
11.39%
Between 3 and 4 years
16
7.92%
Between 4 and 5 years
19
9.41%
Between 5 and 6 years
16
7.92%
Have not changed it
103
50.99%
Voters: 202. You may not vote on this poll
Poll - Battery Life
Old Mar 15, 2011 | 01:09 AM
Rossi6998's Avatar
Rossi6998
Default Poll - Battery Life
I am interested in battery life on C6 STOCK ONLY corvettes. I would like to know when you had to replace your factory installed battery due to failure.
For this purpose, "Stock only" means there has been no electrical modifications to the vehicle, such as replaced factory radio with different model, modified lighting (except replacing existing interior bulbs with LED bulbs), or modification of car's computer module (Dyno Tune).
I am curious if there is any connection between making modifications to your car and "Dead Battery Syndrome".
The poll will close in 10 days.
Old Mar 15, 2011 | 01:14 AM
Cloaked323's Avatar
Cloaked323
I've had mine since April 2007 car sits for weeks at a time, no tender, but now I have a service charging system light flashing randomly, I'd rather the battery dead if that is the cause.
Old Mar 15, 2011 | 01:16 AM
WMark's Avatar
WMark
St. Jude Donor '11
2010, purchased in April '10. Had to replace battery in December. Now have a battery tender. Ain't taking any chances.
Old Mar 15, 2011 | 01:25 AM
obxchartercaptain's Avatar
obxchartercaptain
FL Events Coordinator
Mine is a 08 Vert....purchased new in March 08, which if the Nuns taught me correctly is 3 years old. 20,000 miles... NO tender...longest sitting without being driven is 3 weeks. No battery problems.
And, in the for what it's worth dept.... A 04 Silverado 4x4 Purchased new in Aug 04.. 56,000 miles....Still on the ORIGINAL battery....Longest not being driven...2 months. NO TENDER Had to jump it once 2 yrs ago.
Old Mar 15, 2011 | 01:29 AM
4thC4at60's Avatar
4thC4at60
Bought my '07 in September '06... same battery, no charger: DD
Old Mar 15, 2011 | 01:30 AM
MARSC6's Avatar
MARSC6
Stock or modified doesn't matter. Leave these cars sit long enough and the battery is drained. Other cars will do it as well but they're typically driven much more so it isn't a problem.
Old Mar 15, 2011 | 01:37 AM
Rossi6998's Avatar
Rossi6998
That may be so, but I am more interested in battery failure and not the occasional, "I didn't drive the car, so the battery is dead issue." I indicated "Stock Only" because I am trying to rule out as many variables as possible.
Thanks for the input - Appreciate it...
Old Mar 15, 2011 | 02:03 AM
Rob 99's Avatar
Rob 99
I'm "Apache" a psycho dog
Picked up my built to order 07' in June of that year still have org batt no signs of any probs.(Batt Tender used during non use periods)
Old Mar 15, 2011 | 03:27 AM
Mike's LS3's Avatar
Mike's LS3
Original battery since Dec. 2007, 36k miles and still going. I throw on a Cteck charger every 3 or 4 months for a maintenance charge which keeps the battery in a healthy state. My car has sat for up to 3 weeks and fired up like it was driven the day before.
Old Mar 15, 2011 | 03:31 AM
Grzldvt1's Avatar
Grzldvt1
Car was picked up in Oct 04, battery finally died last year in January. Put an Interstate in it and won't have any issues for another 8-9 years.
Old Mar 15, 2011 | 03:53 AM
keyplyr's Avatar
keyplyr
I'm assuming the Delco battery was installed sometime mid '04 since my '05 was an early build according to the VIN. It died a quick death with no warning at a little over 5 1/2 years, but I couldn't be happier with its performance.
For the last 2 years I've used an Optima Yellow Top battery which easily handles direct lines to both 450W and 750W audio amps and I couldn't be happier with its performance.
Old Mar 15, 2011 | 08:09 AM
jimmie jam's Avatar
jimmie jam
4 years and three months. 5,600 miles and original Delco still strong.
Old Mar 15, 2011 | 08:19 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Took delivery 4/07 (4 years). No hint of a problem so far. The car didn't sit on a dealer lot for months and I use a Battery Tender.
Old Mar 15, 2011 | 11:44 AM
miami08VETTE's Avatar
miami08VETTE
Mine developed a hairline crack around the positive terminal. Caused nasty acid to leak and completely corrode the positve cable. Dealer had to replace battery and the pos/neg wire harness. Fortunately it all happened just prior to the 3/36 warranty expiration so it was all on GM's dime.
Old Mar 15, 2011 | 11:50 AM
Raazor's Avatar
Raazor
Goon Squad King of Battle
St. Jude 15 Year Donor
St. Jude Donor '08 thru '23
still stock on an 07
Old Mar 15, 2011 | 11:54 AM
johan gouws's Avatar
johan gouws
'05 and no issues.
Old Mar 15, 2011 | 11:55 AM
hawkgfr's Avatar
hawkgfr
Mine was built in spring of 07....still working perfectly...@35k miles never had a charge.
To Poll - Battery Life
Old Mar 15, 2011 | 11:59 AM
NYC6's Avatar
NYC6
Didnt vote in the poll but useful data to offer.
06 Car with upgraded audio(2 JL amps 750w total) 2+ years ago upgrade was installed.
Still on OEM battery. Car has never had a tender on it in its life. Car also sits idle for weeks at a time in an unheaded garage in NY winters. When replacement time comes, OEM battery going in.
Old Mar 15, 2011 | 12:01 PM
j_digi454's Avatar
j_digi454
Same here 4 1/2 years and still going.
Old Mar 15, 2011 | 12:05 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
'05 purchased new in June '05.....weekend driver.....on battery tender over winters. Original Delco still running strong although I did purchase an Optima Red Top (type 25) that I intend to install as a precaution soon as the weather warms up a bit.
