Front end alignment
Old Mar 16, 2011 | 08:31 PM
shelleygraham's Avatar
shelleygraham
Default Front end alignment
Can anyone post the pfadt align specs to be adjusted for longer tire threasd wear. Thanks. Did google it but didn't really get anywhere. I just got new tires and I need an alignment and want to adjust it so my tires will last me longer. Thanks.
Old Mar 16, 2011 | 08:34 PM
RicK T's Avatar
RicK T
http://www.pfadtracing.com/docs/camb...t-settings.pdf
FWIW, I don't completely agree with it but what do I know.
Old Mar 16, 2011 | 08:50 PM
gunterwalker's Avatar
gunterwalker
From: Cape May, NJ; Guntersville, AL; Orange Beach, AL
I would tell them you want 0 camber. I would think that would make the tread wear even. I don't know this for sure but it makes sense to me. Personally I would leave it with the "performance" alignment. It handles better.
Old Mar 16, 2011 | 08:58 PM
shelleygraham
Is the performance alignment factory settings ?
Old Mar 16, 2011 | 09:01 PM
gunterwalker
From everything I have read up on the factory allignment they do it so the car performs a little better but the tread wears faster. If I didn't drive the car hard I might have it adjusted to get more tread life. If it was my DD I would probably change it so my tires lasted longer.
Edit: You might want to call Pfadt and see what they say. I'm sure they would be very helpful.
Old Mar 16, 2011 | 09:30 PM
JoesC5's Avatar
JoesC5
I'm having mine aligned next week when the new tires are installed. I'm 100% street so I'm going with an alignment that will, hopefully, give me maximum tire life.
Front:
camber -0.6 deg
caster 8.0 deg
toe 0.0 inch
Rear:
camber -o.4 deg
toe 0.0 inch
Old Mar 16, 2011 | 09:32 PM
shelleygraham
Front:
camber -0.6 deg
caster 8.0 deg
toe 0.0 inch
Rear:
camber -o.4 deg
toe 0.0 inch
Thanks hope so !!!
Old Mar 16, 2011 | 09:41 PM
Kdurgin's Avatar
Kdurgin
With exactly zero toe it may want to wander when going straight. I'm surprised it calls for zero.
Old Mar 16, 2011 | 09:58 PM
shelleygraham
I hope it doesn't. i hate when it pulls.
Old Mar 16, 2011 | 10:12 PM
Lubrecon's Avatar
Lubrecon
Default Factory Specs
I just got the factory service manuals. Alignment depends on which suspension you have, FE1, 2, 3, 4, or 5. I haven't found out which suspension applies to which car, but my guess is the FE1, 2, or 3, apply to the base car and the GS car. FE4, and 5, probably apply to the Z06 and the ZR1. Here are the caster, camber, and toe. There are also cross caster, steering wheel angle, and thrust angle specs.
Front
FE1,2 ,3 Camber: -0.45 degrees +-0.60 degrees
Caster: 7.5 degrees +-0.60 degrees
Total Toe: 0.10 degrees +-0.20 degrees
FE4 Camber: -.95 degrees +-0.60 degrees
Caster: 7.6 degrees +-0.60 degrees
Total Toe: .10 degrees +-0.20 degrees
FE5 Camber: -1.00 degrees +-0.60 degrees
Caster: 7.7 degrees +-0.60 degrees
Rear
FE1, 2, 3 Camber: -0.45 degrees +-0.60 degrees
Total Toe: -0.00 degree +-0.20 degrees
FE4 Camber: -1.20 degrees+-0.60 degrees
Total Toe: -0.00 degrees+-0.20 degrees
FE5 Camber: -1.25 degrees+-0.60 degrees
Total Toe: 0.10 degrees+-0.20 degrees
If anyone wants the other specs just ask and I will post those also.
I don't know what a -0.00 is????
Old Mar 16, 2011 | 10:53 PM
Lubrecon's Avatar
Lubrecon
If all else fails, read my post!!
Old Mar 16, 2011 | 10:58 PM
Snake.Oiler's Avatar
Snake.Oiler
St. Jude Donor '13 thru '20,'22,'24 thru '26
The GS would be the FE3
Old Mar 17, 2011 | 12:12 AM
saplumr's Avatar
saplumr
With the factory allowable specs your going to get close...a little close or somewhat close.
Old Mar 17, 2011 | 12:23 AM
LionGS's Avatar
LionGS
Old Mar 17, 2011 | 01:21 AM
fnsblum's Avatar
fnsblum
When I had new tires put on 7K miles back the camber was at -.4 The tires are wearing very evenly. Later! Frank
Old Mar 17, 2011 | 03:21 AM
hebdog7's Avatar
hebdog7
The toe is what greatly affects the tire wear. The camber not as much BUT if you have a lot of - or + camber it will then factor in a good amount of toe in or toe out and you tires won't last for long.
I went with the street Pfadt settings but left a little more camber in for spirited driving. I have 0 toe at all four corners and it doesnt pull and handles just fine. I dont track it as it is my DD.
Old Mar 17, 2011 | 09:00 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
How about spending 5 minutes and become an "expert" on tire alignments. http://www.tirerack.com/tires/tirete...e.jsp?techid=4
Then you can measure what your current settings are http://www.davidfarmerstuff.com/align.pdf and decide how you want to change them.
To Front end alignment
Old Mar 17, 2011 | 09:25 AM
Bandit1's Avatar
Bandit1
PFADT's Recommended Corvette Alignment Settings:
Pure Street
Front
Camber -0.8deg
Caster 8.0deg
Toe 0.0in
Rear
Camber -0.5deg
Toe 0.0in
Dual Street/Track
Front
Camber -1.2deg
Caster 5 to 8deg
Toe 0.0in
Rear
Camber -0.8deg
Toe 0.0in
Notes: For using street tires and driving to and from the track.
This setting will work for R-compounds at the track.
Old Mar 17, 2011 | 10:17 AM
G Morse's Avatar
G Morse
The inside of my front tires was shot in less than 30,000. I took it to my dealer just before replacing the front tires and told the technician to set up my alignment for maximum tire wear. I don't know the specs he used, but my new front tires have been on for 10,000 miles and they are wearing perfectly.
Old Mar 17, 2011 | 10:38 AM
Larry/car's Avatar
Larry/car
My car still has the factory allignment, at 7,000 miles, the tire wear is even and the handling is super. When it isn't broke don't mess with it.
