Hud
Old Mar 17, 2011 | 09:16 AM
Ttoi's Avatar
Ttoi
Default Hud
Can you change the display color of your HUD?
Old Mar 17, 2011 | 09:26 AM
Andrew6@TheDoubleAA's Avatar
0Andrew6@TheDoubleAA
Former Vendor
Houston Events Coordinator
St. Jude Donor '11-'12, '14
I believe in the Beer Fairy
not that I'm aware of. Shouldn't be overly hard as the old pontiac HUDs' were Red in color.
Old Mar 17, 2011 | 09:49 AM
legbuh's Avatar
legbuh
I wish there was a way to put more information on the HUD.. like a clock and outside temp.. changing color would also be pretty cool.
Old Mar 17, 2011 | 10:41 AM
redls3's Avatar
redls3
i think a red Hud would be awesome
Old Mar 17, 2011 | 10:49 AM
Z06Ronald's Avatar
Z06Ronald
The current color is the most ergonomic
Old Mar 17, 2011 | 09:30 PM
C7Joy's Avatar
C7Joy
I think I go along with that idea. The greenish color does not seem to intrude on your attention when it shouldn't, yet it is easy to find when you want it. I am trying to imagine red and other colors and it just doesn't seem to pop for me.
Old Mar 17, 2011 | 09:46 PM
SSTEVEGS's Avatar
SSTEVEGS
Red is the best color for night. It will not dialate your pupils and and negatively affect your night vision like other colors; especially white. Most aircraft have red instrument panel lighting for this reason. Pontiac had a good thing going with their red dash lights! I think BMW currently uses red on their cars.
Old Mar 17, 2011 | 10:08 PM
ghostRder's Avatar
ghostRder
Old Mar 17, 2011 | 10:09 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
True, but...
When I started with United Airlines in 1969, all the cockpit lights were red. By about 1975, they had changed everything to conventional white. The reasoning was that white light made the instruments easier to read, less eyestrain, true rendition of colors on maps, manuals, etc. Because of those advantages, we could turn down the brightness and still read the instruments properly.
So, the advantages of red lighting turned out to be less than we thought in the real world. I'm not sure how a red HUD would compare to the green in daily, opps, nightly, use.
Old Mar 18, 2011 | 01:46 AM
DigitalWidgets's Avatar
DigitalWidgets
From what I understand, human eyes see green light much better than they see red light. That's supposed to be why you can see green laser lights so much better than red laser lights.
I'm also thinking that because the HUD needs to work in direct sunlight that red would not be bright enough.
That all being said, I bet you could buy a small pieces of color lighting gels used in professional lighting applications, and just cut to size and drop it into the HUD display.
Something like this:
http://www.google.com/products/catal...d=0CE4Q8wIwAw#
Old Mar 18, 2011 | 05:21 AM
mac823's Avatar
mac823
Originally Posted by Gearhead Jim
True, but...
Yuppp exactly what I was just about to say....the backlighting on the gauges in the helicopters I fly are light red and the normal lighting is white/light yellow. As you know as well it's not necessarily the color that messes with your eyes as much but staring at objects.
Personally I think a bright red HUD would be intrusive on the eyes
Old Mar 18, 2011 | 05:57 AM
keyplyr's Avatar
keyplyr
The green work for me
Old Mar 18, 2011 | 08:37 AM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
I worked F-16's while active duty and the HUD display is green and the backlighting is white unless it is night vision modded then the backlighting is blue-green. The F-15 is set up the same way with the exception of the multi-colour displays. The HUD is also green.
As for the Vette, I prefer the C6 HUD display over the C5 and I'm OK with the colour.
Old Mar 18, 2011 | 09:07 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Originally Posted by DigitalWidgets
...That all being said, I bet you could buy a small pieces of color lighting gels used in professional lighting applications, and just cut to size and drop it into the HUD display.
Before someone goes out and spends a lot of money, the HUD is green. The light is green. You can't magically turn green into red or orange or yellow or... Color gels work by REMOVING colors, not adding them. Take a white light and remove every color except yellow and you get a yellow picture. Take a light that has no yellow and run it through a yellow filter and you get black.
Old Mar 18, 2011 | 09:51 AM
TheRedGS's Avatar
TheRedGS
I like the green lighting in the HUD. It would be nice to have different color options, but I do agree with FortMorganAl.
Old Mar 18, 2011 | 01:58 PM
DigitalWidgets
Yes....I suppose I didn't think this one all the way through. FortMorganAl is absolutely right. Lighting gels are subtractive....you start with white and remove all the other colors that you don't want. If the light from the HUD does not contain elements of the desired color, it won't show through (i.e. if the HUD's light color doesn't contain at least some white mixed in there a gel will just block it out).
I do think the green of the HUD works amazingly well. It's still usable at noon on a sunny Southern California day, and also works great on the darkest of nights. For a projector type of technology to work under that wide array of conditions is pretty impressive to me (although, I guess it's not really a projector, just a two-way mirror type of thing). Either way, the HUD is one of my favorite features (behind the 436 ponies that is!).
Old Sep 16, 2013 | 10:22 PM
Former Vendor
Old Thread but yes...
To Hud
Old Jan 5, 2018 | 11:04 PM
Andrew Halliday's Avatar
Andrew Halliday
1st Gear
My car is doing the same thing. What did you find out op? At first the hud would flash full brightness over the whole display then it did it more and more and now it is at full brightness all the time. It is really annoying especially at night I turned it so I can’t see most of it but I miss my HUD and would really like to fix the problem. Thanks
Old Jan 5, 2018 | 11:10 PM
Adam Cifonelli's Avatar
Adam Cifonelli
Is there anyway to update the software to make it look like the C7s and Camaros HUD?
Old Jan 5, 2018 | 11:37 PM
jrose7004's Avatar
jrose7004
I'm not able to change mine as far as I know.
