octane rating
Old Mar 20, 2011 | 06:02 PM
RT2SJB's Avatar
RT2SJB
Default octane rating
Is it possible to run a stock c-6 on lower octane gas? I usually run 93 but am considering using 89. Any thoughts?
Old Mar 20, 2011 | 06:04 PM
EDinPA's Avatar
EDinPA
Where are you and do you drive like an old woman?
Old Mar 20, 2011 | 06:07 PM
ncvette_1FUNRIDE's Avatar
ncvette_1FUNRIDE
2015 C6 of the Year Finalist
Not sure what year you have but I can tell you this. When I picked up my 2010 at the Corvette Museum I was specifically told that is was just fine to use regular octane gas in the Corvette. The car's computer system is designed to adjust according to the octane gas that is being used.
I do run 93 in mine BUT it is not necessary. Regular will work just fine. You may have slightly lower HP but it won't hurt anything.
Old Mar 20, 2011 | 06:13 PM
RT2SJB's Avatar
RT2SJB
I have an 07 with 15,000 miles on it and no i do not drive like an old woman. There is always one on this thread.
Old Mar 20, 2011 | 06:39 PM
EDinPA's Avatar
EDinPA
Sorry to be 'the one'
Also sorry you do not realize that it is pertinent to your question. Sorry too that you did not answer where you are at.
If you are in a warm climate AND you drive spirited THEN yes it does matter as your engine will pull timing to make up for the crap gas. It can only pull so much however and you would risk detonation.
If you live where it is cooler and drive like an old woman and never put the engine under load, then have at it with the cheap gas.
Old Mar 20, 2011 | 06:42 PM
gunterwalker's Avatar
gunterwalker
From: Cape May, NJ; Guntersville, AL; Orange Beach, AL
I don't think he was being an A$$. He asked questions that need to be answered so he can give you the answer to your question. People on here are really soft skinned.
Old Mar 20, 2011 | 08:27 PM
goatts's Avatar
goatts
93 octane is the recommended fuel. You should only run regular if the higher octane is not available. On regular you will lose power and your engine may knock in which case the knock sensor should detect it, if it doesn't then you could damage your motor. Do a search, many threads on this. There is also info in the owners manual.
Old Mar 20, 2011 | 08:30 PM
SlasherMcGee's Avatar
SlasherMcGee
There's no 93 in my area so I'll be running 91, if that helps..
Old Mar 20, 2011 | 08:41 PM
spinalator's Avatar
spinalator
I thought we were supposed to use race fuel...
Old Mar 20, 2011 | 09:06 PM
Vette5.5's Avatar
Vette5.5
Actually believe only the ZO6 LS7 recommend's 93 octane for maximum power, with the the LS-2, 3 engine's being a point or two lower. You can run all of these on 87 octane in a pinch taking it easy, but not intended as a steady diet. If looking for a way to save maybe $1.50 per filll up with 87, what's the point of owning a Vette', and with the dialed back timing, mpg's going to drop down anyway.
Old Mar 20, 2011 | 09:07 PM
RedVette84's Avatar
RedVette84
If they recommend 93 I use it. You are not saving alot of money by going to the lower octane. If it was a Ford Focus I wouldn't care but unless you driving many miles daily really what is your savings. On a fill up it might be a couple of bucks. That's like when I'm tanking up and there's a well healed Jaguar owner with a 12 cyl. car pumping in 87 octane.
Old Mar 20, 2011 | 09:13 PM
shelleygraham's Avatar
shelleygraham
I run nothing but 93 !
Old Mar 20, 2011 | 09:21 PM
brianc6z16's Avatar
brianc6z16
Here is right from the owners manual:
Recommended Fuel
If the vehicle has the 6.2L V8 engine
(VIN Code W), use premium
unleaded gasoline with a posted
octane rating of 91 or higher. You
can also use regular unleaded
gasoline rated at 87 octane or
higher, but the vehicle's acceleration
could be slightly reduced, and a
slight audible knocking noise,
commonly referred to as spark
knock, might be heard. If the octane
is less than 87, a heavy knocking
noise might be heard when driving.
If this occurs, use a gasoline rated
at 87 octane or higher as soon as
possible. Otherwise, you could
damage the engine. If heavy
knocking is heard when using
higher, the engine needs service.
(VIN Code T) or the 7.0L V8 engine
(VIN Code E), use premium
octane rating of 91 or higher. For
best performance, use premium
octane rating of 93. In an
emergency, you can use regular
unleaded gasoline with an octane
rating of 87 or higher. If 87 octane
fuel is used, do not perform any
aggressive driving maneuvers such
as wide open throttle applications.
You might also hear audible spark
knock during acceleration. Refill the
tank with premium fuel as soon as
possible to avoid damaging the
engine. If heavy knocking is heard
when using gasoline rated at
91 octane or higher, the engine
needs service.
As already stated, if you use lower octane fuel the computer compensates and gives you less horsepower and LESS MPG. You will have to decide if it is worth it.
Old Mar 20, 2011 | 09:24 PM
Don-Vette's Avatar
Don-Vette
93 here,why run anything else just to save about $3.50 a tankful? lol
Old Mar 20, 2011 | 11:09 PM
Z06LUST's Avatar
Z06LUST
St. Jude Donor '12
WHY? Unless you have a Z06/LS7 your engine is factory tuned for 91. Anything above 91 is worthless.
Old Mar 20, 2011 | 11:11 PM
Z06LUST's Avatar
Z06LUST
St. Jude Donor '12
They don't for the LS2 and LS3. Both are set up for 91.
ONLY the Z06 with the LS7 is tuned for 93.
Old Mar 20, 2011 | 11:19 PM
richie15's Avatar
richie15
It's not worth engine damage to save a buck or two on fuel.
To octane rating
Old Mar 20, 2011 | 11:29 PM
vettedoogie's Avatar
vettedoogie
So you can't read your manual?
Old Mar 20, 2011 | 11:43 PM
ctsv510's Avatar
ctsv510
$0.20 per gallon savings, 15 gallon fill ups, $3 saved per fill up. If you fill up once a week then you'll save yourself about $12 next month.
If you drive a lot and fill up every other weekday then you'll save about $30 a month. If you are worried about $30 a month, why are you driving a c6?
Old Mar 20, 2011 | 11:51 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Maybe because it is not needed and it isn't available in half the places these cars are sold, that in itself is proof you don't need it.
