I dont know if this is just a reg t56 or a TR6060!! I tried looking up part #'s with no avail.....I cant find this part # anywhere!! Most I figured out (I think) is it was built march 15th in 09 which if its built in o9 its a tr6060 correct? Thanks!
Just thought about it and it is from a Z51 or a Z06 (hence the cooler return fitting in the side,its also in the 08 only location). If you count the output shaft spline count (27=Z51 and 30=Z06) the Z51 will have a 2.97 first gear and the Z06 has a 2.66 first gear ratio.
That looks like a Ford tranny, it has BOSS embossed on it.
I would say it rides pretty rough though from the looks of things, also probably smokes a lot.
