bug in headlight
Old Mar 23, 2011 | 02:49 PM
zsmasher's Avatar
zsmasher
Default bug in headlight
Some how a moth got into my headlight on my c6 has anyone had this happen? and how do i get it out ZSmasher
Old Mar 23, 2011 | 03:11 PM
brooklync5's Avatar
brooklync5
Well they eat through things like clothes. Check the rubber seal around the headlight and look for some sort of hole I guess. As far as getting it out ask rlseabring he has experience with headlights and is always asking for a bad pair. My guess is he refinishes them to re sell so he's probably familiar with taking them apart and putting them back together. Good luck.
Old Mar 23, 2011 | 03:14 PM
zsmasher's Avatar
zsmasher
thanks for info bud
Old Mar 23, 2011 | 03:17 PM
brooklync5's Avatar
brooklync5
You got it. Weird situation you find yourself in.
Old Mar 23, 2011 | 03:23 PM
zsmasher's Avatar
zsmasher
Yeah there's a 1/4 inch gap around bezel that's how he must have got in but he's dead now and cant fly out. trying to figure a way to get 1/4 inch vacuum in that gap around bezel, irritates the crap out of me everytime i look at it
Old Mar 23, 2011 | 03:31 PM
legbuh's Avatar
legbuh
I did a mod on one of my bikes once that I had to vacuum out shavings through a small hole. I took a little rubber hose that fit in the hole, taped it to the end of my shop vac and inserted it into the hole and cleaned it out.. pretty easy! Hope the hole is big enough for something like that.
Old Mar 23, 2011 | 03:35 PM
zsmasher's Avatar
zsmasher
That is along the line im thinking i think the moth will turn to dust when i hit it, hopefuly not all over inside of lens cross my fingers
Old Mar 23, 2011 | 04:27 PM
B y r o n's Avatar
B y r o n
Pull one of the bulb and put the vacuum hose over it and see if that works.
Old Mar 23, 2011 | 04:52 PM
Blaq Ops's Avatar
Blaq Ops
Old Mar 23, 2011 | 05:05 PM
c54u's Avatar
c54u
no biggie....passenger for life.
i have a spider in mine, and its been there for 2 years.
i have had no luck getting it out either. so be it
Old Mar 23, 2011 | 05:08 PM
zsmasher's Avatar
zsmasher
I got a spider and moth in same one, its gota go
Old Mar 23, 2011 | 05:11 PM
zsmasher's Avatar
zsmasher
If i do that bro that the moth will be bouncing around like a pinball and powder all over the inside of lens i don't want that
Old Mar 23, 2011 | 08:26 PM
rorad's Avatar
rorad
I wish I had an answer for ya but all I can do is relate to your problem. I have a huge horse fly in mine. It was so embarrassing, the first day I drove my vette to work and showed it off to my friend. He walks around the car, looks me dead in the eye and says "what's up with the bug in your headlight". Not, "sweet ride", he focuses on the stinkin' bug. I plan to change out my lens soon (they look crappy too) and say good bye to Mr. Bug.
Old Mar 23, 2011 | 08:49 PM
speedraider's Avatar
speedraider
one in a million......
Old Mar 23, 2011 | 09:01 PM
deacongator's Avatar
deacongator
Default Spiders
I can relate to this problem. I have a spider (now dead) inside my 2010 GS passenger side headlight assembly. Cob webs everywhere. I could have the entire headlight module replaced (under warranty) but I am afraid the dealership may screw things up. So, for now I'll just live with it.
Old Mar 23, 2011 | 09:10 PM
B y r o n's Avatar
B y r o n
Shouldn't bounce around if you start with the hose held back and then slowly put it closer to the hole, should just slide out.
Old Mar 23, 2011 | 09:21 PM
Boomer111's Avatar
Boomer111
I have had a handful of ants in mine from day one. Dealer just blew me off.
I had forgotten about them for awhile.
To bug in headlight
Old Mar 23, 2011 | 10:13 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
I think the next time my lights are apart I'll use a rubber gasket and keep my lens removable for such occasions. I keep getting those extra large mosquito's in my passenger side light. No visual entry point.
Old Mar 23, 2011 | 10:40 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
The headlight assemblies are not sealed air tight.
This allows moisture/condensation to evaporate.
Unfortunately, bugs can get in too.
If you leave the car out in the sun for a few days, and/or use a hairdryer you may be able to dry out/shrink the culprit to the point that you may be able to suck it out with a piece of aquarium tubing attached to your vac.
Old Mar 24, 2011 | 12:01 AM
tt3000gt's Avatar
tt3000gt
