z51 rotor question
Old Mar 23, 2011 | 03:15 PM
Munky's Avatar
Munky
Default z51 rotor question
For all you z51 owners. I am going to need to rotors and pads soon, and was wondering where the best place to get replacement rotors is. I am toying with upgrading to z06 calipers etc., but not certain I can justify the cost difference with the wife just yet.
Let me know what you guys recommend. Thanks.
Also - my wheels will allow for z06 set up.
Old Mar 23, 2011 | 03:55 PM
BobBass's Avatar
BobBass
Man, if this was me, this would be the perfect excuse to "move up" to the Z06 brake setup. I HATE the look of the wimpy rear caliper on my Z51.
Old Mar 23, 2011 | 04:16 PM
Jimini's Avatar
Jimini
If it were me , I'd stick with stock parts and use my local dealership as a source to do the work
Old Mar 23, 2011 | 04:43 PM
Peter_H's Avatar
Peter_H
I changed my base model over to Z51 brakes and I got the rotors and larger brackets from Parts Taxi, a vendor here. I've seen them listed at other vendors also. The Parts Taxi ones are zinc coated, which is nice.
Old Mar 23, 2011 | 05:42 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Got mine from the local dealer for the same price as the vendors shipped price those babies are heavy
Old Mar 23, 2011 | 06:08 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Old Mar 23, 2011 | 06:16 PM
breecher_7's Avatar
breecher_7
Z06 brake upgrade is a nice touch but your looking at about 1500 to do it if you look hard for the parts then you will also need new wheels as they dont fit under the stockers.
Z51 rotors can be had from the dealer for just over $300 (there cost is even less, if you shake them down you can get them right around $300) Or you can get nice rust proof coated ones from Mike at TPS motorsports for around $380 I believe.
Id go for the Z06 brakes if I were you, other then appearance, the Z51 brakes really dont do anything for you.
Old Mar 23, 2011 | 06:57 PM
Gravy's Avatar
Gravy
Cruising
This article has some pretty good suggestion on base C6 brake upgrades. I think the rotors are pretty cool.
http://www.vetteweb.com/tech/vemp_09...ade/index.html
Old Mar 23, 2011 | 07:04 PM
breecher_7's Avatar
breecher_7
For what your going to pay for those rotors you would be better off upgrading to Z06 brakes and having more stopping power and better looks.
To z51 rotor question
