LED light question
Old Mar 28, 2011 | 08:35 PM
Andrew6@TheDoubleAA's Avatar
0Andrew6@TheDoubleAA
Former Vendor
Houston Events Coordinator
St. Jude Donor '11-'12, '14
I believe in the Beer Fairy
Default LED light question
I bought a set of the Fender cove lights from JWM. They look great and the question I have is if I want to add more LED lights do I have to go through the whole set up of adding new power and negative with remotes and resistors or can I tap in to existing wires going to LED's to fender coves for power etc...?
Old Mar 28, 2011 | 08:46 PM
DAS ZED's Avatar
DAS ZED
Probably ok to tap into, What size wire did you use? What size fuse did you use? What else is on the circuit?
Old Mar 28, 2011 | 08:52 PM
Former Vendor
has a led strip going to each of the fender cove, 10 amp fuse, nothing else on circuit and wire looks to be about the size of speaker wire that comes with any standard speaker you buy in the store?
To LED light question
