Rotor Disaster
Old Mar 30, 2011 | 02:49 PM
shelleygraham's Avatar
shelleygraham
Default Rotor Disaster
I had my rotors zinc plated. I brought them to be powder coated. The guy called me today and said we have a major problem He was suppose to powder coat the centers. He said before he powder coats he has to put a chrome finish on it and baked it at 400 degrees. The high heat and zinc coating made major air bubbles and he cant powder coat them in this condition . He is stripping the down. Will that take off the zinc plating. If I re zinc coat and send them to Customs by Mike will this happen again ? Thanks.
Old Mar 30, 2011 | 03:01 PM
bobwoodkat's Avatar
bobwoodkat
I have had that problem on Non automotive parts that I manufacture. We zinc all our parts and problem isn't the zinc. The part itself is out gassing. The best way to keep that from happening is to pre heat the part. Bake it out at 50 degrees hotter then your normal powder bake temp. Let it cool to the point where the powder can be applied then bake it out at 50 degrees lower then normal for a longer period. This has always worked for my parts.
Old Mar 30, 2011 | 03:06 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
say wha????
I just had my rotors powdercoated locally and they did no such thing...WTF would they chrome something to powdercoat over it???That makes NO sense whatsoever.
Old Mar 30, 2011 | 03:24 PM
shelleygraham
He said he did that he knows about out gassing. He is stripping the powder coating off and cleaning them up and they will still have my original zinc coat on them. I contacted Mike the powder coater and I am going to send them to him.
Old Mar 30, 2011 | 03:29 PM
redzone's Avatar
redzone
Originally Posted by pewter99
say wha????
That guy is retarded......
I've had many things powder coated & none were chromed first.
Old Mar 30, 2011 | 04:02 PM
Vasta's Avatar
Vasta
St. Jude Donor '06-'07-'08-'09-'10-'11-12-'13-'14-'15-'16
Usually they want me to sandblast my part clean before I take to the powdercoating guys.
Old Mar 30, 2011 | 04:21 PM
XSQUID's Avatar
XSQUID
Yeah, we do powdercoating here where I work, and properly prepped is required but it doesnt mean chroming. Like the man said, someone is retarded.
Old Mar 30, 2011 | 05:58 PM
Brian2010's Avatar
Brian2010
I guess younjust have to send them to an expert.
Old Mar 30, 2011 | 06:52 PM
Swiftrider08's Avatar
Swiftrider08
Some of your mods I really don't understand, and this is one of them, but it is YOUR car, so do as you please.
Old Mar 30, 2011 | 06:54 PM
gilly6993's Avatar
gilly6993
St. Jude Donor '08
the Japan earthquake was a disaster.....this isn't
Old Mar 30, 2011 | 07:03 PM
saplumr's Avatar
saplumr
If you were going to have them powder coated what was the reason for zinc plate? I assume you are attempting to protect the rotor edge.
Old Mar 30, 2011 | 07:50 PM
BigDs_C6's Avatar
BigDs_C6
The "chrome" the powder coater is refering to is most likely a simulated chrome colored powder that is put on as a base prior to a candy or metallic color.
As far as the powder not sticking to the zinc, it depends on how the platers zinced them. Realistically the best way to do it is to strip the zinc from the areas that will be powder coated. Your powder coater should have masked all the areas you want to save the zinc on and then blasted the areas he wanted to coat. Alluminum oxide would be the best choice, 120 grit at around 50 psi should remove all of the zinc on the areas he's going to coat.
D
Old Mar 30, 2011 | 08:06 PM
cclive's Avatar
cclive
Zinc plating is tough for some things to adhere to. This can be a problem when trying to paint something that is galvanized.
Old Mar 30, 2011 | 08:22 PM
BigDs_C6's Avatar
BigDs_C6
The more I think about it, the more I wonder why you would want to powder coat instead of the zinc?.. The zinc is a much better corrosion resistant coating and it should be more durable.
Just so you know that I've got a clue as to what I'm talking about, here's some pictures of some rotors that I plated a couple weeks ago. When I say " I plated", I mean I physically plated these. They are Electroless Nickel plated. The only way to get a true even plating in all of the recesses like the drilled areas and fins is to electroless plate them. Some of the cyanide based plating solutions like cadmium have great throwing power, but due to the environmental aspects zinc is a much better choice... I just don't have that option right now though.
I picked these up used really just to see what I could do with them. A lot of prep work, the shinier they are going in, the shinier they are coming out.. I still need to get them resurfaced.
D
Old Mar 30, 2011 | 08:26 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
I too am baffled by the need to zinc plate the rotors before powder coating.
Are there areas of the wheel that will be zinc and others that are powder or is the whole rotor (except the swept area) going to be powder coated and the zinc is necessary as some kind of base coat?
Either way, good luck.
Old Mar 30, 2011 | 08:40 PM
saplumr's Avatar
saplumr
D
OK...this is a really silly question but I have to ask. Did you actually nickel plate the swept area on those rotors? I assume that must be a optical illusion because that can be done and drive them on the street.
Old Mar 30, 2011 | 08:46 PM
shelleygraham
I zinc coated to help reduce rust etc. Mike the powder coater told me I had to zinc plate before powder coating. The guy was preparing them to put metallic JSB in the center not actually chrome. Maybe I wasnt suppose to zinc plate where the powder coating was going ? I wonder if I send them to Mike he can fix everything. He just did an awesome job on my calipers and lug nuts. I have a call into him. Thx.
To Rotor Disaster
Old Mar 30, 2011 | 08:52 PM
ZBADESTZ@Straightline's Avatar
Sorry to hear that Shelly...
On a side note did you receive my thread?
Old Mar 30, 2011 | 08:54 PM
shelleygraham
Diidn't check today's mail yet. I just got home will let you know. Thanks so much for sending it. I hope it matches. Really appreciate your thoughfulness.
Old Mar 30, 2011 | 09:02 PM
SlasherMcGee's Avatar
SlasherMcGee
sucks ....
