Splash Guards
Old Mar 31, 2011 | 12:38 PM
Black05's Avatar
Black05
Default Splash Guards
Does anyone have splash guards on their C6?
Do they look OK?
Are they difficuklt to install?
Old Mar 31, 2011 | 12:50 PM
Thompyt's Avatar
Thompyt
Not difficult to install. Look fine installed. I used the OEM type designed for the vehicle.
Old Mar 31, 2011 | 12:51 PM
lefthander's Avatar
lefthander
St. Jude Donor '07-'09
Have been investigating this myself. At our local gathering I have seen three styles. The stock C6 seem to be a bit small to do any good, but install easily. You can try the Aepsis but there is some fitting required , and they cost more. The Z06 guards look good but there is some trimming and cutting required to make then fit and look good. No answer but I hope this helps. I still have,nt done anything, maybe won,t.
Old Mar 31, 2011 | 01:05 PM
sampaschal's Avatar
sampaschal
For around $100 bucks..the stock GM splash guards can't be beat IMHO. Look good...fit perfect.
Old Mar 31, 2011 | 01:10 PM
cclive's Avatar
cclive
They look like the car was made with them and they work.
Top_Fuel's Avatar
Top_Fuel
Check this thread.
Old Mar 31, 2011 | 01:20 PM
MARSC6's Avatar
MARSC6
I went with these http://www.mamotorworks.com/corvette...-305-6776.html
Just a couple minutes to install with no drilling.
Old Mar 31, 2011 | 02:50 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Had them on mine since the purchase
Old Mar 31, 2011 | 10:15 PM
cmonkey713's Avatar
cmonkey713
GM guards are a perfect fit becuase they are OEM parts. About $100 or so and 20 minutes and you are done.
Old Apr 1, 2011 | 09:09 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
You can click on my thread below to get the price and to order, etc. I have also scanned in the instructions and posted them in the thread.
http://forums.corvetteforum.com/c6-p...rts-house.html
Old Apr 1, 2011 | 09:19 PM
SSTEVEGS's Avatar
SSTEVEGS
I finally put OEM's on last weekend after waiting for 62 degrees. I bought them in January but it's been a long, cold winter. The front ones are really easy and take about 5 minutes...the back ones require drilling into the inner fender wells for installatioin and take a bit longer. I think the temperature requirement for the OEM (Gene Culley) is 62 to 85 degrees. The GS and Z06 have splash guards; all Corvettes should have them! They look great and give the wheel wells a more sophisticated, and finished look.
Old Apr 1, 2011 | 09:29 PM
SSTEVEGS's Avatar
SSTEVEGS
Here's a before pic:
Old Apr 1, 2011 | 11:08 PM
Stew24's Avatar
Stew24
I pulled my OEM C6 splash guards off the rear and replaced them with OEM Z06/GS rear splash guards. They look great! Took a bit of planning, trimming, twisting, but they came out looking factory installed and almost make my Vette look like a wide body (My wheel offset also pushes the tires almost out of the fender).
Will try to get pics tomorrow.
Old Apr 2, 2011 | 05:20 PM
Just 4 2's Avatar
Just 4 2
I have aspis all around. look god and they work.guess i could send a pic if you like .
Old Apr 2, 2011 | 07:22 PM
arrowhead's Avatar
arrowhead
I bought the OEM's---With the weather here, it will be June before I can get them on.
Old Apr 2, 2011 | 10:54 PM
dads fun's Avatar
dads fun
Me to fit great, small but effective and not hard to put on
Mine look like they were factory installed and it took about 2 hours working slow.
Old Apr 2, 2011 | 11:16 PM
Justasheet's Avatar
Justasheet
To Splash Guards
Old Apr 2, 2011 | 11:40 PM
Silverado Desperado's Avatar
Silverado Desperado
Post more pics !!! (please)
Old Apr 3, 2011 | 07:38 AM
BevoZ06's Avatar
BevoZ06
St. Jude Donor '11-'12
I bought the OEM guards from Gene Culley at GM Parts House. Easy installation and they look as if they came from the factory that way -- and they should have.
Old Apr 3, 2011 | 05:35 PM
Stew24's Avatar
Stew24
Here are my OEM Z06 guards. Came out great. Not even the slightest gap in the fitting.
