LS3 Oil Filter
1 Post
LS3 Oil Filter
Just called the local AutoZone to check on availability of an AC PF-44 for my 2011 GS LS3 A6 and was told that this P/N had been superseded by PF-46. Is this right? I don't have my Owner's Manual available to check.
Thanks.
Thanks.
The 44 and 46 are not the right filter for your car. It has a different bypass system in it. From page 11-8 of the 2011 owners manual:
11-8 Service and Maintenance
Maintenance Replacement Parts
Replacement parts identified below by name, part number, or specification can be obtained from your dealer.
Part GM Part Number ACDelco Part Number
Engine Air Cleaner/Filter
6.2L LS3 V8 and 7.0L LS7 V8 Engines 15776148 A3077C
6.2L LS9 V8 Supercharged Engine 25940997 A3107C
Engine Oil Filter
6.2L LS3 V8 Engine 89017524 PF48
6.2L LS3 V8 Engine with Z52 Dry Sump Oil System 12626224 UPF-48R
6.2L LS9 V8 Supercharged Engine 12626224 UPF-48R
7.0L LS7 V8 Engine 12626224 UPF-48R
Passenger Compartment Air Filter Element 15848592 CF139
Spark Plug
6.2L LS3 V8 Engine 12621258 41-110
6.2L LS9 V8 Supercharged Engine 12571165 41-104
7.0L LS7 V8 Engine 12571165 41-104
Wiper Blades — 52.5 cm (20.7 in)
Driver Side 12335960 —
Passenger Side 12335961 —
Your car should use the 48 filter.
Engine Oil Filter
Spark Plug
Could be an April Fools joke, but in case it isn't..your car takes a PF48 or UPF48R or a Mobil1 M1-113 or a K&N HP-1017 or a WIX 57060 or a Purolator PL12222.
I use the Mobil1 and K&N filters.
