Dash Noise... Seeking Help !
Old Apr 2, 2011 | 11:38 AM
SuperSonic's Avatar
SuperSonic
Default Dash Noise... Seeking Help !
07 Coupe, Noise coming from passenger side in dash. Not believe to be blower. It's something that will start and stop on it's own at any giving time. Annoying especially to passenger. Can someone relate ? Any suggestions as to what I can look at or do ? Thanks for any help....
Old Apr 2, 2011 | 11:44 AM
cthusker's Avatar
cthusker
Need a little more info... Is the noise when are you moving, sitting still or both? Can be very different problems based on when you are hearing it.... What kind of noise? Squeaking, rattle.. etc.... again different causes for different noises.... Was the car stored for the winter? A wide variety of possibilities so it helps to supply more info for educated guesses here...
Old Apr 2, 2011 | 11:47 AM
AirBusPilot's Avatar
AirBusPilot
Does it only happen while driving?
If so, take a length of masking tape and tape the plastic windshield wiper blade cover to the windshield and go for a drive again.
If the noise goes away it is being caused by air passing between the plastic wiper cover and windshield. I fixed mine by putting a small bead of clear silicone underneath the wiper cover glueing it to the windshield. Easily removed later. Mine was also on the passenger side. I didn't glue the entire cover, just about 18" on that side.
Old Apr 9, 2011 | 07:31 PM
SuperSonic's Avatar
SuperSonic
Got it done today. Thanks Sir. Good information, Corrected problem.
Old Apr 9, 2011 | 07:43 PM
PatriotZ's Avatar
PatriotZ
Veteran: Marine Corps
From: "No matter where you go... there you are"...."You cannot drive a dollar bill". ...and remember... "D
Great info here Pilot....I used black electrical and thought I would have to live with it....mine only made noise above 80mph...or buy a new blade cover......think I will try your method....thanks for the info again
Old Apr 9, 2011 | 07:48 PM
BT ZR1's Avatar
BT ZR1
2009 ZR1 SN 1166
Wow, that is an impressive diagnosis
To Dash Noise... Seeking Help !
