Performance axle option
Old Apr 5, 2011 | 03:05 PM
LarryMJones's Avatar
LarryMJones
Veteran: National Guard
St. Jude Donor '13-'14-'15-'16-'17
Default Performance axle option
I was just on the Vette site build your own vehicle, and found no reference to the optional rear end ratios that used to be available. Have they been discontinued?
LJ
Old Apr 5, 2011 | 04:01 PM
KWC6's Avatar
KWC6
LJ
I believe only the 2.73 is available on a6, where as the 2.56 use to be standard.
Old Apr 5, 2011 | 04:14 PM
Vette_DD's Avatar
Vette_DD
2.73 comes with the automatic tranny on the Grand Sport models. 2.56 still comes with the base Vette, no performance axle available. This info. is for 2011 model year.
At least this is what the order book indicates.
Old Apr 5, 2011 | 04:24 PM
LarryMJones
That sounds right, I think the 2.73 used to be lumped in with a handling option so it was likely dropped when GS came along.
LJ
Old Apr 5, 2011 | 05:27 PM
Purdue's Avatar
Purdue
LJ
Discontinued as a stand alone option for model years 2010 and 2011. 2.73's come standard on the GS models with automatic trans.
My 2009 A6 came with 2.73's as a stand alone option.
You are correct! It was originally offered as part of the Z51 package as well as a stand alone for 2008 and 2009 model years.
Old Apr 5, 2011 | 06:33 PM
Vette5.5's Avatar
Vette5.5
2.56 is the standard axle on most C6 auto's, with the 2.73 for the GS's. Really not a big deal, since first gear on the A6 is 4.05, or a ratio combination most 60's muscle car guy's would be wetting themselve's over. M6 car's get 3.42 axles, but the tranny's first is only 2.66, so pretty close. GS M6's get slightly lower tranny gearing to offset the extra curb weight.
Old Apr 5, 2011 | 07:34 PM
Vette_DD's Avatar
Vette_DD
Gear ratio times rear axle ratio is what it's all about.
To Performance axle option
