2011 GS ignition switch light
Old Apr 8, 2011 | 04:34 PM
dfarese's Avatar
dfarese
Default 2011 GS ignition switch light
I have a 2011 GS and I have seen it a lot of pictures that the ignition switch has a light that lights up green, mine looks like just a painted white line. Am I missing something?
Old Apr 8, 2011 | 05:02 PM
legbuh's Avatar
legbuh
When I get in mine it lights up green. May want to talk to the dealer.
Old Apr 8, 2011 | 05:09 PM
cclive's Avatar
cclive
The green circle that is around the circular arrow on the button glows green...
Old Apr 8, 2011 | 05:45 PM
Davelt1coupe2010's Avatar
Davelt1coupe2010
yep, really nice feature at night time.
Old Apr 8, 2011 | 05:53 PM
lastcowboy's Avatar
lastcowboy
changed mine to blue
Old Apr 8, 2011 | 06:30 PM
EVRose's Avatar
EVRose
And this is how it looks green with a lot of the paint scratched off. I need a new one.
Old Apr 8, 2011 | 06:40 PM
dfarese's Avatar
dfarese
**** sorry guys just noticed I wrote 2011 GS I meant 2010 GS, and mine does not do that, it just is a white painted circle. On 2010 is it suppose to have that light also, i like that.
Old Apr 8, 2011 | 06:41 PM
lastcowboy's Avatar
lastcowboy
Cool
Old Apr 8, 2011 | 06:53 PM
bluman's Avatar
bluman
I have a 2010 and it lights up green, you may have a bad led light in the back of the switch.
Old Apr 8, 2011 | 07:13 PM
cclive's Avatar
cclive
All C6s are the same this way.
Old Apr 8, 2011 | 07:40 PM
dfarese's Avatar
dfarese
Really they all light up?
**** maybe my light is bad like bluman said. but on mine, it looks like it's just a painted line, not a plastic strip that would light up.
Old Apr 8, 2011 | 09:50 PM
mpuzach's Avatar
mpuzach
If my memory serves me correctly, it lights up green when you enter the car (when you open the door, actually) but shuts off after the engine is started. I'll try to verify later.
Old Apr 8, 2011 | 11:13 PM
mpuzach's Avatar
mpuzach
I just confirmed this. Here's the chain of events I just observed in my car:
  1. While simply sitting unoccupied, nothing is illuminated.
  2. When I open the driver's door, the green circle lights up as do the graphics at the bottom (the small circle in the lower left and "ACC")in the lower right .
  3. Once I start the car, the green circle darkens but the graphics at the bottom stay lit.
  4. When I shut off the engine, the graphics at the bottom stay lit and the red light under the backlit circle (lower left) lights. The large circle does not light.
  5. When I open the door to exit, nothing changes.
  6. When I close the door after exiting, the large green circle lights up and all other lighting on the starter switch goes off. I didn't stick around long enough to see how long the green circle stays lit.
Bottom line: The green circle lights up when opening the door from the outside and goes off after starting the engine. It also lights up after closing the door upon exiting the car. Otherwise, it's off.
dfarese's Avatar
dfarese
Thanks buddy, I just checked mine today, I guess ever since I bought it it's had a dead light in it.
Old Apr 8, 2011 | 11:15 PM
mpuzach's Avatar
mpuzach
Check out post # 13.
Old Apr 8, 2011 | 11:55 PM
cclive's Avatar
cclive
Mike is of course correct and I would add that the green circle is the last thing to turn off after closing the driver's door. It goes off just as the overhead lights dim all the way and go off. Its just an LED or two inside the switch, so easy to see it just being bad...simple fix.
To 2011 GS ignition switch light
