Power Window problem
Old Apr 10, 2011 | 01:25 PM
corvetteconvert57's Avatar
corvetteconvert57
Default Power Window problem
It finally hit 70 degrees here in Detroit today and I unveiled the '08 C6(after being covered since Nov) and went to wash it. Unfortunately more water got inside the car than outside because the power windows did not automatically seal up when the door was shut. Neither side... Has this every happened to anyone before? The car is under warranty with only 5k miles but I'm still pissed.. Any thoughts?
Old Apr 10, 2011 | 01:29 PM
Vette_DD's Avatar
Vette_DD
Close the car door. Raise the window and hold the up switch an extra 3 seconds. Release. Without lowering the window, hold the up switch again for 3 seconds. Release. Done.
This is called resetting of the window indexing or power window initialize and is in the owner's manual. See page 2-17 of the 2005 owner’s manual, page 2-18 of the 2006 owner’s manual, page 87 of the 2007 owner’s manual, page 2-18 of the 2008 owner’s manual, page 2-18 of the 2009 owner's manual, page 3-18 of the 2010 owner's manual, or 2-18 of the 2011 owner's manual. -JFP
You'll have to do it every time the battery is reconnected.
You also would have found it if you'd looked at the C6 FAQ sticky.
Old Apr 10, 2011 | 02:44 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
I'm beginning to think there needs to be a sticky
"Before asking a question, PLEASE RTFM!"
Old Apr 10, 2011 | 02:46 PM
BT ZR1's Avatar
BT ZR1
2009 ZR1 SN 1166
Old Apr 10, 2011 | 04:07 PM
cclive's Avatar
cclive
Any time the battery goes dead or is disconnected, this needs to be done. It tells the computer where the position of the window is.
Old Apr 10, 2011 | 04:15 PM
cthusker's Avatar
cthusker
Why.. this is only the 10000th time this question has been asked..
Old Apr 10, 2011 | 05:09 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Well, I'd say that getting a car full of water is sufficient punishment.
Let's go easy on him.
Bet he doesn't do it again!
Old Apr 10, 2011 | 06:49 PM
Vette_DD's Avatar
Vette_DD
It was a sticky before the links for several stickies was combined into one thread and the re-index thread was unstickied. Would be helpful if it were made a sticky again.
Old Apr 11, 2011 | 10:31 PM
corvetteconvert57
Well "excuse me" for asking... Isn't this a Corvette Forum? Not a political venting post?
Get off your high HORSE!
Old Apr 11, 2011 | 10:32 PM
Vette_DD's Avatar
Vette_DD
Just got to learn to ignore responses that bother you.
Old Apr 11, 2011 | 10:37 PM
corvetteconvert57
Thanks for the advice JIMTN... I'm still learning my way around the forum.
And thanks for the tips on re-setting/re-indexing. Strange thing is it did not happen when I stored it the year before. Anyways..Thanks again
To Power Window problem
