Anyone know how to get into my C6?
Both FOB's get close to the car but do not unlock. All buttons work on FOB save for the hatch one and unlock one. I can lock it, and I can make it alarm only.
Can't get in and the manual is, well, in the car. It's a 2005 coupe auto.
Any thoughts on how to get into my car, lol..........
Use your trunk key. Once you're in there, there's a mechanical latch on the right that opens the driver's door.
George
Moderator
Received 3,579 Likes
Sounds like you need new batteries for the fobs as well. CR2032
St. Jude Donor '10
St. Jude Donor '10
Not sure about that. I was just testing it, so the FOB was working. I just used that to turn off the alarm.......that is after I changed my shorts. The hood was up, so that alarm was a loud mother and scared the crap out of me. I'm sure the neighbors enjoyed me screaming like a little girl....
Lock and Key Tech will insert a a "air wedge ' at rear of drivers window and insert a long adjustable rod and hit the door button.If that doesn't work the rod must snag the release cord between the seat and the door.
See chapter 2 in the online owners manual:
http://www.gmpartshouse.com/download...05corvette.pdf
If you've never used the metal key:
http://forums.corvetteforum.com/c6-c...metal-key.html
Tips for replacing fob battery:
http://forums.corvetteforum.com/c6-c...y-warning.html
Thanks all for the help. Not only were the FOB batteries dead but car battery was dead as well. I had the "double whammy" of battery issues. Eventually got in through the hatch and charged the battery. All good....for now.
And no I haven't used the car much as an FYI.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
it will have to grab the emergency release handle betw. the door and seat, if I'm correct, since pushing the door button won't do it. if it's locked, you'll need to first push the toggle button for lock/unlock, then the door button.
