Mild2Wild
Apr 12, 2011 | 01:39 PM
Mild2Wild
Will Mild2Wild work in a 2008 ZHZ.
I tried both methods of installing the unit.
Nothing works
This is the 3rd unit that I have tried
Apr 12, 2011 | 01:52 PM
Just pull the fuse and be done with it.
Who wants a mild sounding C6 with the
LS3 engine?
Apr 12, 2011 | 01:56 PM
That is how I have it now. Hard to sneek in the garage with that rumble.
Apr 12, 2011 | 04:37 PM
Ok, if I just pull the fuse, the exhaust will be open all the time ?
Is anything else affected by pulling the fuse ?/
Apr 12, 2011 | 05:02 PM
St. Jude Donor '15 thru '26
Quote:
Originally Posted by
Stan0324
Wont affect anything else. No worries. Just enjoy the sound of heaven!
Apr 12, 2011 | 05:09 PM
joel_prahl@budweiser
Nothing works
Are you mounting it with the red wire facing the console, and white wire up? Hooking up ground (black wires). Blue antenna wire up? Hope this helps. Right from my instructions from Mid America.
Apr 12, 2011 | 05:36 PM
Try a different bolt/nut/screw to attach the ground wire.
Mine didn't work after following the M2W instructions to attach it to a screw in the footwell fusebox. Used a VOM to find a viable ground and all was well.
There shouldn't be a problem hooking it up. It's basically replacing a fuse with another remote controlled fuse.
Apr 13, 2011 | 01:29 AM
Houston Events Coordinator
St. Jude Donor '11-'12, '14
I believe in the Beer Fairy
shouldn't have a problem. Probably just not grounding well. First mod my ZHZ got.
Apr 13, 2011 | 07:08 AM
Torchsport
As
Jay Leno said about pulling the fuse on the C6's
dual mode exhaust system...
"Noise is good!"
http://www.jaylenosgarage.com/at-the...exhaust-trick/
Apr 14, 2011 | 01:46 PM
Thanks, it was a bad ground. IT WORKS! The one they said to use wasn't good.
Now I can sneek in at night and not wake up the neighbors! Thanks for the heads up.
Apr 14, 2011 | 02:08 PM
Let me recommend that you go for the "no battery drain" installation. That setup is included in the instructions.
