The battery on my '06, standard C6, is getting a bit slow and I wanted to replace it. My dealer service rep seemed to be strongly discouraging me from replacing it with a new Delco. He was suggesting that I would be much better off with an Optima.
I live in San Diego where there seem to be only a few Optima dealers and even then, I'm getting different suggested model numbers from the Optima website and from different shops that sell them. Costco says that they don't cary a battery for an '06 Corvette.
I've searched other postings on the forum and there seems to be no consistancy in which model is correct for an '06.
Does anyone know what the actual correct model number is for this year? I would prefer to just get the Red Top.
Just fyi, I also checked on Interstate batteries and the only one that they say fits, was poorly rated (per Consumer Reports) and is on "national back-order", probably to correct the problems that they have had with it.
If your replacing the original Delco battery that came with the car 5 years ago I'd say stick with the Delco. That's a long time for a battery to last.
For DD I have a lead-acid, AGM Optima Red Top (group 25, part #9025-160). Great, reliable and fast starting - however it's heavy (31.7lbs.)
Part Number: 25 (9025-160)
RedTop®; lead-acid, AGM Battery; Group 25; Cold Crank Amps 720; Crank Amps 910; Reserve Capacity 90; Ampere Hour 44; Top Terminal; L-9 5/16 in.; W-6 3/4 in.; H-7 5/8 in.
Originally Posted by OptimaJim
...our batteries are lead-acid, AGM batteries in a SpiralCell design. They can be treated and charged just like regular lead-acid batteries in most situations, but they are not "gel" batteries and "gel" or "gel/AGM" charger settings should be avoided, as they will not fully-charge our batteries and could damage them over time. If you have any questions about our batteries, I'll do my best to answer them.
Jim McIlvaine
eCare Manager, OPTIMA Batteries, Inc.
How can you tell it's getting a bit slow? I have a 2006 I just bought recently and I am pretty sure it still has the stock battery in it. So I was thinking of replacing it before I get stuck stranded somewhere. So I was just curious what to look for to tell the battery is near the end of it's life, or as you say, "getting slow".
[QUOTE=keyplyr;1577333924]For DD I have a lead-acid, AGM Optima Red Top (group 25, part #9025-160). Great, reliable and fast starting - however it's heavy (31.7lbs.)
My is a DD, so I'm not worried about the weight, so much. At NAPA, they said the the Group 25 battery was correct, but on the Optima site, is says you need a Group 35. It is kind of confusing. Is the 25 a direct fit, with no modifications?
Thanks!
There is a slight hesitation in the start-up, when you press the start button.
The battery is so old that I think it is better to be safe than sorry.
Battery shop, auto service place, dealer and many auto parts stores can do a load test. This will test your battery's ability to produce a high amount of current and maintain a minimum voltage.
If the battery does not produce enough current or the voltage falls to low, the battery is weak.
Autozone sell's Optima's.
A good thing to do is watch your voltage meter. A fully charged battery will show about 14 1/2. If that thing starts dropping to the 13s you will have a problem in the future. That's exactly what happened to my 6 year old yellow top optima.
Those are great batteries by the way. I have a red top that is in it's 6th year and still going strong.
The OEM battery in my '06 seemed to be getting weaker but it turned out the negative terminal was loose. Check them first. I use a battery tender all the time.
For an '06, if you want an Optima Red Top, a Type 35 battery is correct, the positive terminal is on the driver's side, a Type 25 is identical but the terminals are reversed.
Or you can get an Optima Yellow Top D35, this is their deep-cycle battery that can be discharged to a greater depth and still be revived.
Check out 1st-Optima-batteries online. Easy to understand charts with dimensions, terminal positions and pricing.
Other slightly larger Optima's will fit, even ones with the terminals reversed from stock will work with not too much fussing.
Lots of debate on the Forum about performance vs. price with these batteries. I've had good luck with most of mine.
The battery on my April built 2006 coupe died recently. Of all the times for it to die, it was up on my drive-up ramps just after I completed a oil change. I could not start it to circulate the oil and drive it off the ramps. Hooked up a battery tender for a coupe of hours and was able to start it. I bought a Everlast battery from Auto Zone and it fit perfectly. I think it was about $112.00. 700 cold cranking amps and it works just fine. Three years full warranty and eight pro-rated. Good Luck with your decision.
I also have an 06' with a 6 speed manual Z51 and still with the original battery. I use a battery tender during the winter month when the car is not being used. The original battery on my Lexus lasted almost 8 years, also on a tender when not being used for an extended period of time. I also carry in the compartment in the trunk a portable battery just in case, the day when I have to use it is the day I'll replace the battery.
I got a Optima Yellow Top Type 34 (only top terminals, with the Positive on the Left (passengers side) I beat the hell out of it.. at the track.. ... Make a 1/4 mile run, then shut off the car but run the fan & electric water pump for 5-7 min to cool it to 150.. with no problem....
Sometimes I'll make 10 runs a day, and its been fine for 2 years now..
I went through two GM batteries and kept having a low or dead battery.
I finally bit the bullet and bought an Optima Red Top and have not had a problem since.
My Vette actually sat for three months without me starting it and when I finally went to start it...It fired right up with the Optima
