TPMS battery life
Old Apr 15, 2011 | 05:47 PM
HOXXOH's Avatar
HOXXOH
Default TPMS battery life
After several searches I've found the following generally accepted information.
Owner's Manual states battery life is 10 years.
Sensors go into sleep mode at time of manufacture.
Information is transmitted once per hour in sleep mode.
Sleep mode resets 15 minutes after activity ceases.
From sleep mode the car must first reach 15 MPH to switch to active mode.
Information is transmitted once per minute in active mode.
Obviously, mileage has no direct relationship to the battery life, other than a number GM picked along with an average speed to determine signal transmissions.
How the car is used, is a better indication of the time expected before the sensors need to be replaced.
I'd be far more interested to know the estimated number of signal transmissions before a battery failure. Knowing the way I use my car, it would help me decide which time I replace the tires to also replace all the sensors.
Old Apr 15, 2011 | 05:51 PM
Rocketmanwpb's Avatar
Rocketmanwpb
10 years is probably underestimating the battery life. I would not worry about it because when a unit fails you will get a message on the DIC.
Old Apr 15, 2011 | 06:38 PM
Thrill6's Avatar
Thrill6
Just had one (the first) go out in my '99 C5 with around 65k miles. That's 12 years, so I don't think you'll need to worry about the ones in your C6 for quite some time.
Old Apr 15, 2011 | 09:50 PM
HOXXOH's Avatar
HOXXOH
Your case is exactly why I asked the question. 12 years, but only 65K on the clock. My '08 already has 83K miles and one of the sensors has already flashed the DIC a couple of times. It reset itself on the next start cycle, but I'm curious how much longer before it and any other ones completely die.
To TPMS battery life
