ZO6 Targa?
Old Apr 19, 2011 | 05:34 PM
SoonEnough's Avatar
SoonEnough
Default ZO6 Targa?
Is their a way to modify a ZO6 to fit a regular C6's removable roof? I can't see myself owning a corvette without targa.
Old Apr 19, 2011 | 05:44 PM
Torchsport's Avatar
Torchsport
St. Jude Donor '15 thru '26
The chassis/alum frame wont support the lack of rigidity. Might be better to throw a LS7 into a Grand Sport!
Old Apr 19, 2011 | 05:54 PM
EDinPA's Avatar
EDinPA
It can be done, but it is expensive.
I had the same problem when shopping. I opted for a GS with a blower.
Old Apr 19, 2011 | 05:55 PM
User 81424's Avatar
User 81424
Yes, for a lot of money Caravaggio will do it. He worked with Corvette engineers and I believe it adds 80lbs of bracing to the frame.
Old Apr 19, 2011 | 06:16 PM
Vito.A's Avatar
Vito.A
Caravaggio does the removable top Z06 conversions for about $12k. A shop in Bowling Green KY did a forum members new Z06 for around $10k. The extreme expense involves bracing the Z06 aluminum frame.
He did a detailed writeup with pictures and road race testing. He also goes into great detail on the aluminum frame strength and comparisons with other model Corvette frames. I also saw a write up where they cut a Z06 in half and added doublers to the inside of the alum frame before adding the removable top.
There is another less expensive option. You can have a transparent roof panel bonded to your Z06 roof frame. It is not removable, but at least see through. If interested, you can contact Thompson Astro tops. The trick here is to locate an inexpensive donor transparency.
There are some of us that doubt the extra frame strengthening is necessary, but that's another discussion.
Old Apr 19, 2011 | 06:55 PM
User 81424's Avatar
User 81424
Can you provide links to the write ups?
Old Apr 23, 2011 | 08:20 PM
Vito.A's Avatar
Vito.A
Default Several of you asked for the links:
NVR2L8 is the subject matter expert.
http://forums.corvetteforum.com/show...ight=Targa+top
http://forums.corvetteforum.com/c6-z...-write-up.html
http://forums.corvetteforum.com/c6-z...dy-set-go.html
Old Apr 24, 2011 | 01:57 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
That's the one thing GM could do that might open my wallet.
Old Apr 24, 2011 | 02:55 PM
smurfkiller's Avatar
smurfkiller
buy a gs and supercharge it. then really you could have a targa or even vert with zr1 power.
Old Apr 24, 2011 | 04:55 PM
tampatopless's Avatar
tampatopless
There is a guy in Tampa who converts C5 Z's to convertibles. He has done quite a few.
Not sure about C6s. If you are interested, it's the Corvette Shop on Dale Mabry Highway.
Old Apr 24, 2011 | 09:25 PM
nubrand's Avatar
nubrand
Default Just buy this one
http://forums.corvetteforum.com/c6-c...nvertible.html
Old Apr 24, 2011 | 09:27 PM
breecher_7's Avatar
breecher_7
I have a sawzall you can borrow.....
To ZO6 Targa?
