Emissions Check Engine Light
Old Apr 21, 2011 | 02:22 AM
mac823's Avatar
mac823
Originally Posted by DJackman
Mac, since u have a CEL light on due to aftermarket cats chances are u won't pass smog. However u can eliminate the CEL light for good by getting an 02 extention. Go to eBay and type in the word "cel fix" . U will need 2. Good luck
Thank you! I am not too worried about the getting it smogged...just making sure it isn't an issue that's going to cause drivability problems!
I was researching some stuff and it says the code may come up if your 02 sensor has gone bad....although it would be pretty crazy if both 02 sensors went out at the same time lol
Old Apr 21, 2011 | 02:25 AM
Marc V.'s Avatar
Marc V.
A bad sensor will not set those codes.
Old Apr 21, 2011 | 07:25 AM
MARSC6's Avatar
MARSC6
Have the cats been removed?
