#^$*ing Brain Doesn't Work!!!
Old Apr 20, 2011 | 01:58 PM
Blaq Ops's Avatar
Blaq Ops
Default #^$*ing Brain Doesn't Work!!!
I've driven manual cars all of my life. As with anything it becomes second nature. I've forgotten all of the technical aspects of driving a stick such as "what rpm to shift at" or "what gear I should be in at a certain speed". I JUST DROVE!!! Now I have an A6 and tried paddle shifting but my brain just will not allow me to make that connection. I tried imagining that I was driving a manual but no luck. WHat am I doing wrong?
Old Apr 20, 2011 | 02:01 PM
FloridaGrandSport's Avatar
FloridaGrandSport
I think having the paddle shifters on the wheel just doesn't work well with our bodies' coordination. My wife's IS250 allows both paddle and console gearshift shifting; the gearshift is much more intuitive to me.
Old Apr 20, 2011 | 02:03 PM
dvilin's Avatar
dvilin
No help here still have a manual gearbox, just curious why did you make the switch to an auto.
Old Apr 20, 2011 | 02:04 PM
EVRose's Avatar
EVRose
I tried a paddle shift equipped car once that I was renting and got all screwed around too. I kept letting off the gas and trying to push a clutch that wasn't there. I finally just left it in drive.
Old Apr 20, 2011 | 02:07 PM
Who Needs Turbo's Avatar
Who Needs Turbo
I had test driven an A6 w/ paddle shifters to see if I'd like it (since they shift so fast). It totally messed with me and I just couldn't see myself getting used to it.
I've only driven 2 paddle shift cars (VW GTI and 2008 Vette), but with both I just put them in Auto since it was too unnatural to shift.
I'm on board with Car & Driver: Save the Manuals!
Old Apr 20, 2011 | 02:11 PM
Blaq Ops's Avatar
Blaq Ops
It was a convertible so I knew my wife would eventually want to drive it. She can't drive a manual and I definitely didn't want her to destroy a corvette trying to learn. I also was tired of shifting gears in stop-n-go rush hour traffic.
Old Apr 20, 2011 | 02:12 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
You bought an automatic ..... Vern
Old Apr 20, 2011 | 02:17 PM
JPN7075U's Avatar
JPN7075U
Now if it was a rental car, I could help you. Hold it to the floor and start pushing buttons once it's bouncing off the rev limiter. That's good for knocking carbon off the valves also! My wife's M3 and Z4 both have the dual clutch paddle gismo trannies. It's basically a manual with a computer controlling the clutch and shifting. I leave it in "D" because I'm not willing to deal with it. I grow bored quickly. Man must have clutch pedal and shifter! I will not own an automatic myself. My first car was a 4 year old 69 Z28 and it's been sticks and V8's since. Well except for the V10 Viper stint. And man did it sound like ship compared to a V8!
Old Apr 20, 2011 | 02:22 PM
dvilin's Avatar
dvilin
Fair enough, hopefully once you get the hang of the paddle shifters you will enjoy it as much as the manual gearbox.
Old Apr 20, 2011 | 02:30 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I have the same problem. Driving the paddles seems natural if I'm shifting frequently on a twisty road. But in traffic, it' sooooo unnatural.
But overall, I still like the paddles.
Old Apr 20, 2011 | 02:37 PM
Blaq Ops's Avatar
Blaq Ops
I'm really interested in learning how to do it. I was in 2nd gear at about 40mph and then I punched it. I almost broke my neck!! That lag time that's usually there when in drive was totally gone. It took off like a bat outta hell and I loved it. I guess I just need to go back to the basics. At what rpm should I be shifting?
peter pan's Avatar
peter pan
Life Time NCM #2196
It takes some getting used to, I like our A6 for a daily driver
Old Apr 20, 2011 | 02:43 PM
Canis lupus's Avatar
Canis lupus
I don't go by rpm's.... I go by "sound" and what fuel economy I want for the day
Old Apr 20, 2011 | 02:45 PM
Vette_DD's Avatar
Vette_DD
If you want to use the paddles, just watch the tach and shift when you think you need to - probably about 3000 to 3500 rpm. Eventually, you'll get used to the sound telling you when to shift.
After I'd had mine awhile, I quit using the paddles. Just put it in "S" mode and let it do the shifting. Even if you're not going to use the paddles, the advantage of driving in "S" mode is that the tranny will hold the lower gears a little longer if you're getting on the throttle a little.
Old Apr 20, 2011 | 02:51 PM
Vasta's Avatar
Vasta
St. Jude Donor '06-'07-'08-'09-'10-'11-12-'13-'14-'15-'16
Just keep playing around, it will become more intuitive as time goes on.
Old Apr 20, 2011 | 03:02 PM
Blaq Ops's Avatar
Blaq Ops
Originally Posted by JimTN
If you want to use the paddles, just watch the tach and shift when you think you need to - probably about 3000 to 3500 rpm. Eventually, you'll get used to the sound telling you when to shift.After I'd had mine awhile, I quit using the paddles. Just put it in "S" mode and let it do the shifting. Even if you're not going to use the paddles, the advantage of driving in "S" mode is that the tranny will hold the lower gears a little longer if you're getting on the throttle a little.
When I normally drive a manual I hear the engine and know when to shift. For some reason, everytime I drive this car all I can hear in my head is Phil Collins "In the Air Tonight"!!
To #^$*ing Brain Doesn't Work!!!
