The emblems are three pieces. Using a heat gun warm up each side and remove the two inserts, they are held in with silicone. I started at the base of the flags and bent the emblems slightly to expose a corner and used a pencil screwdriver underneath to lift the insert out, but be careful because they will break.
I found that Autozones brand of carb cleaner will not damage the plastic and I cleaned off the factory color and applied mine. I reglued the insert back into the emblem.
If you want a colored border use the 05-07 emblems. If you want the chrome border use the 08-current emblem.
There is a vender here that does these but they paint the outside of the insert, maybe they will do the backside, like the factory, if asked.
I removed all my Corvette emblems on my C6....gives it a " smooth and sinister " look. I am the only one that I know of that did this.
My C6 coupe is black....I put some black " Jake " vinyl decals on....and " C6.R " in place of the stock Corvette Emblems....I love them. Can't even tell until you're up close.
