Always 75 degrees
Old Apr 21, 2011 | 11:11 AM
sam_b's Avatar
sam_b
Default Always 75 degrees
Anyone hear or have this problem. My temp on the climate controls now reads 75 all the time. I have not taken to the dealer for many reasons but could it be a fuse or something simple. Thanks for the help.
Old Apr 21, 2011 | 11:17 AM
RicK T's Avatar
RicK T
It could just be stuck or might need a new sensor. Try this:
Try pressing these 3 buttons simultaneously:
1. Rear defrost (right most climate button)
2. Front defog (2nd right most button)
3. Fan speed increase (4th right most button)
That sequence is supposed to update the temp display immediately and may correct your problem.
Old Apr 21, 2011 | 11:21 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I believe 75 is the default when the system hasn't a clue what the hell temperature it is. If the reset above doesn't fix it, get a temp sensor for <$10 and you might get the darn thing to read correctly.
Elmer
Old Apr 21, 2011 | 12:39 PM
sam_b's Avatar
sam_b
Elmer
Thanks. I will try this and see what happens. Hope this does the trick.
Old Apr 21, 2011 | 01:15 PM
cclive's Avatar
cclive
The reset is fairly picky about all three buttons being pressed exactly simultaneously.
Old Apr 21, 2011 | 02:16 PM
eboggs_jkvl
Moderator emeritus
Crap, I have issues walking and chewing gum! You want 3 things at once? Good Lord!
Old Apr 21, 2011 | 02:37 PM
cclive's Avatar
cclive
Perhaps 2 friends can help.....you can each take a button and then go "one, two THREE!"
Old Apr 21, 2011 | 02:55 PM
kornyboy's Avatar
kornyboy
Yeah, but where does the 2nd friend sit?
Old Apr 21, 2011 | 03:01 PM
fnbrowning's Avatar
fnbrowning
>>"The reset is fairly picky about all three buttons being pressed exactly simultaneously"<<
>>"Crap, I have issues walking and chewing gum! You want 3 things at once? Good Lord!"<<
>>"Perhaps 2 friends can help.....you can each take a button and then go "one, two THREE!"<<
Sorry, not only does all three buttons need to be pressed exactly simultaneously, it also requires two Stargate officers of command grade to do the reset and it has a five minute countdown!
Old Apr 21, 2011 | 03:25 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
If your temperature display is showing a constant 75 and you know that it isn't 75 out and you've driven the car around enough to wake up the outside air temperature reading then your outside air temperature sensor is defective and needs to be replaced. 75 is a default reading that the unit displays when it can't get a valid reading.
Old Apr 21, 2011 | 03:33 PM
KneeDragr's Avatar
KneeDragr
Maybe its just 'wishful thinking' on the part of your Vette.
Old Apr 21, 2011 | 03:38 PM
cclive's Avatar
cclive
It could also be that the sensor is just unplugged..worth checking before anything else...
eboggs_jkvl
Moderator emeritus
I can loan him a few degrees... let's see, it's 88 so 88 minus 75 is...
Wait, wait, I can do this let's see borrow ten and subtract one from the.. no.. no..
Where's my calculator...
13, that's it! 13! I can loan him 13 degrees and I'll have 75!
Elmer
Old Apr 21, 2011 | 03:40 PM
eboggs_jkvl
Moderator emeritus
Does the term "stick in the mud" strike any bells with you!
I'm sure he has ALREADY checked to see if it was connected, right Mr. OP? You did check?
Old Apr 21, 2011 | 07:54 PM
cclive's Avatar
cclive
I'll bet he doesn't even know where the sensor is...and I wouldn't expect him to know without looking around or asking here on the forum.
Old Apr 21, 2011 | 08:09 PM
talon90's Avatar
talon90
NCM Ambassador
Just in case. The sensor is located on the lower right front (passenger side) radiator support rail. It is a small black tube bolted to the support with wires coming out of it to a connector.
Old Apr 21, 2011 | 09:26 PM
sam_b's Avatar
sam_b
Thanks. Yes it's been that way for two months.
To Always 75 degrees
Old Apr 21, 2011 | 09:27 PM
sam_b's Avatar
sam_b
Bingo. Where is it?
Old Apr 21, 2011 | 09:28 PM
sam_b's Avatar
sam_b
Thanks again. I will check that.
Old Apr 21, 2011 | 09:41 PM
tampatopless's Avatar
tampatopless
Maybe the woman in the pix is heating up the car.
What happens when you take her out of the picture?
